110
Oxygen OS Open Beta 2 for the OnePlus 8 and OnePlus 8 Pro
  1. Rahul_Pendurkar
    Cupcake Oct 16, 2020
    Rahul_Pendurkar , via OnePlus 8 Pro , Oct 16, 2020 :
    Hi folks! I'm facing issues trying to install certain apps on my OnePlus 8 Pro which is running on OOS11 Beta 2. I have attached some screenshots related to the issue. Tried every fix possible including sideloading the app from another OnePlus device. Still no luck! Can someone help me out?
  2. H1602708958818
  3. Nihal9992
    Donut Oct 16, 2020
    Nihal9992 , via OnePlus 8 , Oct 16, 2020 :
    I also had the same problem . Try to clear cache and storage of the play store .
  4. Rahul_Pendurkar
  5. Nihal9992
    Donut Oct 16, 2020
    Reset all settings thats what I did . Finally got fixed. It will wipe your data . So keep that in mind
  6. Rahul_Pendurkar
    Might as well wait for the stable build instead of losing out on all the data.
  7. Nihal9992
    Donut Oct 16, 2020
    You are on open beta right ? If yes , you will not get stable build .
  8. Rahul_Pendurkar
  9. Nihal9992
    Donut Oct 16, 2020
  10. Rahul_Pendurkar
    Oh damn! Seems like I don't have any other option left! Unless someone drops a link for the stable build which I'd be able to flash directly over this Beta.
  11. Nihal9992
    Donut Oct 16, 2020
  12. Rahul_Pendurkar
  13. Nihal9992
    Donut Oct 16, 2020
  14. Nihal9992
    Donut Oct 16, 2020
    JacobKhu likes this.
  15. Nihal9992
    Donut Oct 16, 2020
  16. Nihal9992
    Donut Oct 16, 2020
  17. Rahul_Pendurkar
    The link that you've sent is of the stable build of OOS11, right? Might as well flash this instead of waiting for Beta 3. Might as well skip that. What do you say?
  18. Nihal9992
    Donut Oct 16, 2020
  19. Rahul_Pendurkar
  20. Nihal9992
    Donut Oct 16, 2020
