110
Oxygen OS Open Beta 2 for the OnePlus 8 and OnePlus 8 Pro
  1. D1596353181724
    Cupcake Oct 26, 2020
  2. Mazharapps
    Gingerbread Oct 26, 2020
    Mazharapps , via OnePlus 8 Pro , Oct 26, 2020 :
    Which latest update, you are using open beta 2?
  3. N1593679741757
    Froyo Oct 26, 2020
  4. Samsakthi
    Samsakthi , via OnePlus 8 Pro , Oct 26, 2020 :
    No bro, no change of lighting, i tested in a well lit environment and under natural light during an afternoon, when zooming goes beyond 3x, it aggressively switches camera resulting in a shakey video.
  5. D1596353181724
    D1596353181724 , via OnePlus 8 Pro , Oct 26, 2020 :
    It was the system updates .got it updated on 24.10.20
    I'm not sure about open beta 2.. very lame in this filed..
    So plz inform and hepl plz..
    Lukas Istvan likes this.
  6. Arjun Choudhry
    Ice Cream Sandwich Oct 26, 2020
    Arjun Choudhry , Oct 26, 2020 :
    Are you using Beta 2? If yes, did you flash the India specific builds, or did you get the OTA on Beta 1?
  7. Arjun Choudhry
    Did you flash the Indian specific Beta 2 build? It is available in the 2nd post of this thread.
    After flashing that build, I haven't seen GPay in my phone
  8. Suhail_ak , via OnePlus 8 Pro Glacial Green , Oct 26, 2020 :
    I am using that beta 2 indian version...I am not able to uninstall gpay.
  9. Arjun Choudhry
    You meant the Indian version of Google Pay? I guess Google may have made it a compulsory Google app, as the new Google Pay(Indian version) is built using Flutter, and is being used in other regions as well
  10. Suhail_ak , via OnePlus 8 Pro Glacial Green , Oct 26, 2020 :
    Yes...that one. It is pre installed bloatware
  11. Arjun Choudhry
    Like the old Google Pay was built-in in every phone in locations where it was supported, I guess this one will be built-in in every location where it is supported, now India too.
  12. ajaypsingh
  13. ajaypsingh
  14. L1592770828258
    Eclair Oct 26, 2020
  15. Swejuggalo , via OnePlus 8 Pro Ultramarine Blue , Oct 26, 2020 :
    Well... For stability probably not. Some even returned to beta.
    Depends on your long term use. Want to keep on using beta or use stable?
    A new stable would not be that long away (neither do beta 3). You might be better of waiting. Depends what issues you have with beta 2
  16. FlugzeugSK , via OnePlus 8 Pro Ultramarine Blue , Oct 26, 2020 :
    no. been there, gone back to OB2.
    anyway i am little dissapointed. we have probably most expensive phone Oneplus built, and we have this kind of "no support" and lack of communication from OP. instead of bugfixes we have every week new survey about "How we are happy with this buggy update".....
    really? this is how it should be? a flagship killer?
