57
Oxygen OS Open Beta 3 for the OnePlus 8 and OnePlus 8 Pro
  1. NijasMDK
    Donut Oct 29, 2020
  2. YounesCh
    Eclair Oct 29, 2020
    NijasMDK likes this.
  3. Swejuggalo
    OnePlus 9 Series Expert Community Expert Oct 29, 2020
    Swejuggalo , via OnePlus 8 Pro Ultramarine Blue , Oct 29, 2020 :
    Change the icon to something. Then reset it to default.
    Icons would not be enough reason to switch to betas regardless 😉
    APhaniSankara likes this.
  4. Akshay_0157
    Gingerbread Oct 29, 2020
  5. nachiketh7
    Cupcake Oct 29, 2020
    nachiketh7 , via OnePlus 8 Pro , Oct 29, 2020 :
    Since after I've installed the update, my OnePlus 8 Pro's GCam mod is not able to access the Telephoto and Wide Angle cameras on my device.
    This has never happened since the advent of GCam modders supporting auxiliary lenses in their mods. And I'm using the same mod that used to work completely fine before this update.
    Has this something to do with Android's October 2020 Security Patch? They seem to have limited third party access to only the primary camera. Or is this a OnePlus thing?
    Please help/suggest a way to fix this without root.
    Thank you for reading so far!
  6. TheyCalMeZEUS
    Froyo Oct 29, 2020
    TheyCalMeZEUS , via OnePlus 8 , Oct 29, 2020 :
    You need the downgrade package
    Akshay_0157 likes this.
  7. Akshay_0157
    Akshay_0157 , via OnePlus 8 , Oct 29, 2020 :
    Where it can be found? I've checked one of the link and it's taking me to download the very old android 10 downgrade software. Is it only option?
  8. TheyCalMeZEUS
    Froyo Oct 29, 2020
    Yes downgrade package is based on android 10 , after downgrading install the downloaded android 11 package , downgrading will wipe everything
  9. Akshay_0157
    Ohh... thanks 👍🏽
    TheyCalMeZEUS likes this.
  10. hsoc
    Donut Oct 29, 2020
    hsoc , Oct 29, 2020 :
    Which app data did you clear? launchers?
  11. hsoc likes this.
  12. Swejuggalo
    A note for those that actually read and search 😜
    I previously had GPay issues that of some reason began with a GPay update.
    It was solved by disabling contactless payments on my card. Then re-activate it. A new virtual account number was created. Now it works.
    Alejandrofdez343 likes this.
  13. Depon158
    Eclair Oct 29, 2020
    Depon158 , via OnePlus 8 Pro , Oct 29, 2020 :
    Gallery not updating even after OB3
  14. P1578785420722
  15. Swejuggalo
    Not even beta specific. Happens for many.
    It seems to be a common issue for people that have upgraded from 10. But it has happened on 10 users too.
    Known issue from beta. Might not even be a Oneplus issue but perhaps a Google issue.
    https://support.google.com/googleplay/answer/7513003?hl=en
    Or simply
    Aurora Store or manual updates via apkmirror until it's fixed.
    https://auroraoss.com
    Most needed a factory reset to solve this permanently. But even that might not be a 100% solution (backups might affect the end result - so a clean install might fix it better).
    Barely never happens for me (wiped at Developer Preview 3). And if it does I would use Aurora Store.
    Depon158 likes this.
  16. Dawid91
    Jeff1973 likes this.
