57
Oxygen OS Open Beta 3 for the OnePlus 8 and OnePlus 8 Pro
  1. Does!Compute
    KitKat Oct 29, 2020
    Does!Compute , Oct 29, 2020 :
    Slightly smoother for me in Beta 3
  2. Arjun Choudhry likes this.
  3. krishnaE likes this.
  4. SteveCP
    Jelly Bean Oct 29, 2020
    SteveCP , via OnePlus 8 Pro , Oct 29, 2020 :
    Not possible as you are moving to a firmware that doesn't have the same options as 11 and therefore these all need to be removed so fresh install is the only way.
  5. P1578785420722
    Cupcake Oct 29, 2020
    P1578785420722 , via OnePlus 8 Pro , Oct 29, 2020 :
    My alcoholism must be getting worse because that's the only time I'd install beta software on a device I absolutely need to function at all times. I'll just give this eight pro to my teenage son I'm sure he'll brick it sooner rather than later and I can collect on insurance.🤷‍♂️
    Edit: if there isnt a manufacturer solution for this problem there should be a third party paid solution. if there isn't there is absolutely some money to be made figuring this out because it's clear OnePlus isn't the only manufacturer to roll out Android 11 full of bugs.
  6. qvert
    Honeycomb Oct 29, 2020
    qvert , Oct 29, 2020 :
    i have the same issue
    using urnyx gcam...
    was working on beta2 with the same gcam
    nachiketh7 likes this.
  7. SteveCP
    Unfortunately it is easier to unbrick the phone than to collect on the insurance
  8. P1578785420722
    True. I've found a quick form letter from my lawyer works wonders when they don't want to pay. 👌
  9. hsoc
    Donut Oct 29, 2020
    hsoc , Oct 29, 2020 :
    Same on OP8
  10. Swejuggalo
    OnePlus 9 Series Expert Community Expert Oct 29, 2020
    Swejuggalo , via OnePlus 8 Pro Ultramarine Blue , Oct 29, 2020 :
    Would it be so bad if you used Oneplus Switch to restore a backup when having rolled back?
  11. SteveCP
    The issue is that the banking app is not ready for OOS11 this has already been addressed with the developers and they are working.on it so that is not a OP problem.
    The gallery app and messages app issues are OP problems please us the feedback forum for this complaint.
  12. O1597559671574
    Cupcake Oct 30, 2020
    O1597559671574 , via OnePlus 8 Pro , Oct 30, 2020 :
    It is all false claims for marketing .
    My 8pro was working fine before updating to OOS11.
    After updating to OOS11, phone is UI is sluggish .
    Also facing issues with Bluetooth connectivity .
    There is no sound output to Bluetooth headphones.
    Its been almost a week chasing oneplus team but of no use.
    It has ruined phone experience and I feel cheated since I bought flagship phone and now it seems to be of no use.
  13. efks
    Ice Cream Sandwich Oct 30, 2020
  14. FlugzeugSK
    Honeycomb Oct 30, 2020
    FlugzeugSK , Oct 30, 2020 :
    i experienced random network slowing and lagging on OB3, on WiFi and also on data.
    anyway after network setting reset all is working normally so far (more than 24 hours)
  15. adil_vahab
    Donut Oct 30, 2020
    adil_vahab , via OnePlus 8 Pro , Oct 30, 2020 :
    Oh... I am a new user to one plus.. i have 8 pro and just got 11 update and seems like shit.. i like those old slate font, new one is bullshit...if this is beta... can i get it?? Or how long i need to wait for another stable version of 11 OS???
  16. Swejuggalo
    OnePlus 9 Series Expert Community Expert Oct 30, 2020
  17. aicse
    Gingerbread Oct 30, 2020
    aicse , via OnePlus 8 , Oct 30, 2020 :
    Has anyone else this issue inside Settings ?
    The icons for privacy and location are not missing are always white no matter what accent color is set.
    Had this issue starting from first beta test and on stable version is still present
  18. aicse
    What bluetooth headphones do you have ? I had this issue on both beta versions and on stable as well. Reported the issue to the OP team 3 times already and no luck. Every time got an response from them that they were unable to identify what is the problem. But in my case this is not with all bluetooth headphones and mostly when trying to connect via AAC.
    averyelsawyer likes this.
