57
Oxygen OS Open Beta 3 for the OnePlus 8 and OnePlus 8 Pro
  1. SteveCP
    Jelly Bean Oct 28, 2020
    SteveCP , via OnePlus 8 Pro , Oct 28, 2020 :
    There is an Indian specific version
    #81
  2. alwayspk
    Cupcake Oct 28, 2020
    alwayspk , Oct 28, 2020 :
    Just a quick question.
    How many builds will beta normally got until the next stable version comes out?
    #82
  3. G1594888191227
    G1594888191227 , Oct 28, 2020 :
    Beta 1 VOLTE doesnt work Beta 2 VOLTE works now Beta 3 it doesnt work again wtffffffffffffffffffffffffffffffffffffffffffffff and you cant do it manually through pdc cause the drivers arent up to date
    #83
    YounesCh likes this.
  4. SteveCP
    It doesn't work like that, the next stable version will be out when it's ready.
    #84
    alwayspk likes this.
  5. alwayspk
    Ah i see, thanks for the reply.
    #85
  6. Swejuggalo
    OnePlus 9 Series Expert Community Expert Oct 28, 2020
    Swejuggalo , via OnePlus 8 Pro Ultramarine Blue , Oct 28, 2020 :
    It seems to be a common issue for people that have upgraded from 10. But it has happened on 10 users too.
    Known issue from beta. Might not even be a Oneplus issue but perhaps a Google issue.
    https://support.google.com/googleplay/answer/7513003?hl=en
    Or simply
    Aurora Store or manual updates via apkmirror until it's fixed.
    https://auroraoss.com
    Most needed a factory reset to solve this permanently. But even that might not be a 100% solution (backups might affect the end result - so a clean install might fix it better).
    Barely never happens for me (wiped at Developer Preview 3). And if it does I would use Aurora Store.
    #86
    jaboswe likes this.
  7. Mudit@22
    Froyo Oct 28, 2020
    #87
  8. ManuPoonia
    Froyo Oct 28, 2020
    #88
  9. efks
    Ice Cream Sandwich Oct 28, 2020
    efks , Oct 28, 2020 :
    Turn on DC dimming. Fixed greenish for me
    #89
  10. ManuPoonia
    Froyo Oct 28, 2020
    ManuPoonia , via OnePlus 8 , Oct 28, 2020 :
    @Abdul B. The accent colour in notification panel is like shit except the default one. You redesign the notification panel but now it is worst. The colours are very dull and looks very bad all of other accent colours. The icon should be white in the accent colour. But it is black and the other stuff is gray wtf is this 🤨🙄
    #90
    Claudiu Cioloca likes this.
  11. ManuPoonia
    Froyo Oct 28, 2020
    Bro it's about notification panels gray color in OS 10 it was pitch black not gray and that was very cool.
    DC dimming is useful only when the brightness is very low.
    #91
    This_is_varshney likes this.
  12. efks
    Turn on and check again i say second time
    #92
  13. efks
    #93
  14. Rryuk
    Froyo Oct 28, 2020
    #94
  15. hk_o2
    Honeycomb Oct 28, 2020
    #95
    batho and Arjun Choudhry like this.
  16. Swejuggalo
    #96
  17. Rryuk
    Froyo Oct 28, 2020
    Rryuk , via OnePlus 8 , Oct 28, 2020 :
    Ya when the hardware acceleration is enabled it is not downloading the videos..but when it is disabled then it is able to download video but not in hd.
    #97
  18. Rryuk
    Froyo Oct 28, 2020
    Not this one ...you have to go in Amazon prime video app,then in streaming and download option there is a option called hardware acceleration.
    #98
    Swejuggalo likes this.
  19. 16Kevin
    Froyo Oct 28, 2020
    16Kevin , via OnePlus 8 Pro , Oct 28, 2020 :
    Regrettably even a factory reset failed to fix this for me, I'll try the Aurora store. Many thanks for the suggestion.
    #99
  20. Nag4005
    Eclair Oct 28, 2020
