87
Oxygen OS Open Beta 6 for the OnePlus 7T and OnePlus 7T Pro
  1. prabhakar686
    Eclair Jul 17, 2020
    p.pavljasevic likes this.
  2. Praveen fulzele
    Cupcake Jul 17, 2020
  3. pooh81
    Eclair Jul 17, 2020
  4. O1577288012406 likes this.
  5. iamabhijeetpanda , via OnePlus 7T Glacier Blue , Jul 17, 2020 :
    IMEI SV means International Mobile Equipment Identity - Software Version. So, SV simply denotes the software version. ... For example, If IMEI SV for your Device is 38, then the manufacturer will send you the update based on this version number.
    SHAAVEZ likes this.
  6. SahanCZ
    Gingerbread Jul 17, 2020
  7. daheufster
    WhitELighteR likes this.
  8. PRADYUM_Nohara
    Cupcake Jul 18, 2020
  9. saurabhsrivastav
    Donut Jul 18, 2020
  10. MD.Khan
    Froyo Jul 18, 2020
  11. colaker
    colaker , Jul 18, 2020 :
    guys i'd like ask 2 things.
    anyone has problem with down speakers? my phone has too much sizzle after this update and how can i downgrade stock?
  12. T4hir
    T4hir , Jul 18, 2020 :
    Any chance of getting charging animation like the OnePlus 8 when connected to a dash charger?
  13. oldusername
    Gingerbread Jul 18, 2020
  14. BeingIncog
    Nougat Jul 18, 2020
  15. Manveet
    Honeycomb Jul 18, 2020
    Manveet , via OnePlus 7T Pro , Jul 18, 2020 :
    Does anyone else feel thd volume has lowered at max ever so slightly, compared to the previous update. I'm on 7T pro. Since the day I updated I feel it can go higher, but it's at max.
  16. Prajwal_Praveen
    Eclair Jul 18, 2020
    Prajwal_Praveen , via OnePlus 7T , Jul 18, 2020 :
    Camera issue
    Hi, I use a OnePlus 7T and migrated to the beta updates 3 days ago. What I observe is, everything works fine except for the camera. Not all the time but sometimes, when it starts not to work, it doesn't work at all until I restart the phone. Face unlock doesn't work, main stock camera app doesn't work (the app opens but all I see is a black screen and the in app controls don't work), camera used by other apps don't work. All these problems gets resolved after restarting the device... Can anybody suggest a solution?
    TIA.
  17. T4hir
    I know about the warp charge animation
    I was referring to the dash charge or the now called rapid charge.
    On my wife's OP8 it has animation with a dash charger as well as the warp charger.
    Hope this helps clarify
  18. Vaibhav_sinha
    V.I.C.K.Y likes this.
  19. RonNew
    Eclair Jul 18, 2020
    RonNew , via OnePlus 7T , Jul 18, 2020 :
    Experienced one flaw with the bullets wireless z. Once I pause the music with the remote control on the bullets wireless z I can't restart the music using the remote control. I have to use the button on the phone to restart the music. Further I must say all functions of the phone work perfectly. No battery draining or whatsoever. I'm very satisfied with the open beta os.
  20. Rahul.R.K
    Rahul.R.K , Jul 18, 2020 :
    Does it contain Security Patch June 2020? Coz in my 7t pro it's still working on May Security Patch. (in India)
