86
Oxygen OS Open Beta 6 for the OnePlus 7T and OnePlus 7T Pro
  1. PritamPoddar
    Donut Aug 2, 2020
    PritamPoddar , Aug 2, 2020 :
    Ahh... I rolled back to Stable in my 7T, and look at my SOT, Its insane only 50% of battery drained and my SOT is more than 5 hours. appreciate OnePlus. Yeah, but one issue I was facing today was the bluetooth headphone disconnecting frequently.
    The great dane likes this.
  2. sanilmsathyan
    Cupcake Aug 2, 2020
  3. sanilmsathyan
    Cupcake Aug 2, 2020
    sanilmsathyan , via OnePlus 7T , Aug 2, 2020 :
    Bro how did you rollback to stable build
  4. RonNew
    Cupcake Aug 2, 2020
    RonNew , via OnePlus 7T , Aug 2, 2020 :
    As far as I can test Microsoft Edge doesn't crash visiting the same sites.
  5. ssagheer
    Ice Cream Sandwich Aug 2, 2020
    ssagheer , Aug 2, 2020 :
    Yeah Edge works fine for me as well.
    Shouldn't be webview related. It seems to be Chromium 84 related, since Opera also uses that.
    Edge is on old Chromium version, so might be the reason it is not impacted.
    D1586872754821 likes this.
  6. G_Michael_Davis_tnAa , via OnePlus 7T , Aug 2, 2020 :
    So when I go back to the home screen. 2 issues here. About 1 second delay before icons fill back. After about 10 seconds, a previously opened app will open.
    I don't touch the screen or get close. What is this sensitivity?
  7. VB1
    Gingerbread Aug 2, 2020
    VB1 , Aug 2, 2020 :
    Do post an image of the battery usage graph. A bit curious to see your usage.
  8. ajaykumardv
    Eclair Aug 3, 2020
  9. PritamPoddar
    Donut Aug 3, 2020
    PritamPoddar , Aug 3, 2020 :
    Hey, check this...
    VB1 likes this.
  10. PritamPoddar
    Donut Aug 3, 2020
  11. V1570341262779
    Cupcake Aug 3, 2020
  12. V1570341262779
    Cupcake Aug 3, 2020
    V1570341262779 , Aug 3, 2020 :
    is dual channel networking available in open beta 6 for oneplus 7t
  13. V1570341262779
    Cupcake Aug 3, 2020
  14. BeingIncog
    Nougat Aug 3, 2020
    BeingIncog , Aug 3, 2020 :
    yes! stop spamming.
  15. VB1
    Gingerbread Aug 3, 2020
    VB1 , Aug 3, 2020 :
    As per your usage i guess you generally don't game. Browsing, binging tv shows & movies will generally provide you with a good SOT. 5-6hrs of SOT which includes a little bit of gaming will largely be good enough for the 3800mah battery. I am on OB and to be honest i normally don't bother about battery consumption as long as it provides the SOT i stated. Check my usage when i just binged youtube and surfed the web a lil bit. Normally i do game for around 1.5hr.
    Thanks for sharing your usage. Have a great day ahead.. 👍
    PritamPoddar likes this.
  16. bgreddy , via OnePlus 7T Glacier Blue , Aug 3, 2020 :
    But is the update package is lower.what to do
  17. PritamPoddar
    Donut Aug 3, 2020
  18. iamabhijeetpanda , via OnePlus 7T Glacier Blue , Aug 3, 2020 :
    I am also facing this Bluetooth disconnected problem some times. And battery draining issue too.
