86
Oxygen OS Open Beta 6 for the OnePlus 7T and OnePlus 7T Pro
  1. Aliensmille
    Froyo Jul 12, 2020
    Aliensmille , via OnePlus 7T , Jul 12, 2020 :
    drjainmk
    Hello there, I have been facing proximity sensor issue during calls since the very first day. Whenever I make a call the screen randomly lights up and random actions happen.
    Been told its a software issue.
    Has any of the Beta builds solved it?​
    Beta 4 was best version regarding this problem. I reported it very often but they don't really solved that problem.
    I would say in Beta 4 I got this issue 2 times from 10calls.
    I am now at stable 10.0.11 will see how it works here
    surya11496 likes this.
  2. Aliensmille
    Froyo Jul 12, 2020
  3. madhuri4ufriends
    Cupcake Jul 12, 2020
    madhuri4ufriends , Jul 12, 2020 :
    They actually fixed this bug which has been there for quite sometime..All other OEMs display Silent/Other notifications in Status bar as well..
    Fazil Sheik likes this.
  4. beanpolebiker
    Gingerbread Jul 12, 2020
    Z1535301018938 and ramchek like this.
  5. drjainmk
    Donut Jul 12, 2020
    drjainmk , via OnePlus 7T Pro , Jul 12, 2020 :
    Oh. I am not into beta builds. I bought into the OnePlus hype and realised its a great entertainment device, but a pathetic phone. Anyways, thanks.
    Aliensmille likes this.
  6. Anooparcha
    Anooparcha , Jul 12, 2020 :
    not trimming the slow-motion. like play slow motiom when we need
    prajwal_.6 likes this.
  7. Manveet
    Honeycomb Jul 12, 2020
    Manveet , via OnePlus 7T Pro , Jul 12, 2020 :
    Shouldn't have flashed beta then. Roll back.
  8. Manveet
    Edge lighting is already present on pro series
    SoorajMurtadak likes this.
  9. D1591730648430
    Cupcake Jul 13, 2020
  10. M.Bennett
    M.Bennett , via OnePlus 7T , Jul 13, 2020 :
    For those with heating and battery drain: Shut down phone. Start phone and hold volume down button. When it boots, release volume down button. Insert your passcode. Select language. Select wipe data and cache. Select wipe cache. Select yes to wipe cache. Go back. Reboot phone. Voila.
    Edit: it worked for me. I went from a significant drop after install and high temps on back of phone, to a normal temp and actually fairly good battery life!
    BeingIncog likes this.
  11. Lord_of_cache
    Honeycomb Jul 13, 2020
  12. G_Suvankar_Ghosh
    Eclair Jul 13, 2020
  13. Chirag_Gohil
  14. Vaibhav_sinha
  15. VB1
    Gingerbread Jul 13, 2020
    VB1 , via OnePlus 7T , Jul 13, 2020 :
    VoLTE icon on the beta versions are a bit narrow compared to the icon of the Stable version. So it takes a bit of less space than the Stable ones. But you can disable it if you don't want it to be there on the status bar.
  16. Chirag_Gohil
    Chirag_Gohil , via OnePlus 7T , Jul 13, 2020 :
    I know that. But without volte icon doesn't like
  17. P1573236885771
    Eclair Jul 13, 2020
  18. SaikatRaj
