30
Oxygen OS OxygenOS 10.5.5 for the OnePlus 8 Pro
  1. Zoide
    Eclair May 2, 2020
    Zoide , via OnePlus 8 Pro , May 2, 2020 :
    Yeah, I've noticed that the front camera doesn't like focusing up front on my face. It's like the focus is stuck somewhere behind it.
    Does anyone have the same problem? Any fix?
    Thanks
  2. Conn_Ashby
    Cupcake May 2, 2020
  3. gravyplaya
    Eclair May 2, 2020
    gravyplaya , via OnePlus 7 Pro , May 2, 2020 :
    I just got 10.5.6 and still NO DUAL SIM SUPPORT. I bought this upgrade from the 7 Pro just for the 5G. The fact that they released this phone without this basic phone function is more than disappointing. I can't even use the 8Pro because I need to be able to use both Sims. I'm ok with 5G only on one Sim, but this is really crazy.
  4. jimmmysil
    Honeycomb May 2, 2020
    jimmmysil , via OnePlus 8 Pro , May 2, 2020 :
    check what app has drain problems because my op 8 pro has 8 and a half screen on time. I have 150 apps loaded and during night it uses roughly 3-4%. Go to settings, battery and then view detailed usage to see what app drains your battery
  5. Stefaan , via OnePlus 8 Pro Ultramarine Blue , May 2, 2020 :
    strangely this morning it was empty..
    I've unplugged the phone when heading to bed
    jimmmysil likes this.
  6. jimmmysil
    if you want, charge your phone to full. And when it will be again low battery, check the detailed battery usage and post a screenshot here to see what app drains your battery. is the only way to see what's going on
    Stefaan likes this.
  7. Stefaan , via OnePlus 8 Pro Ultramarine Blue , May 2, 2020 :
    you have QHD, 120hz, location, ... all turned on?
  8. jimmmysil
    yeah always, also Bluetooth always on because I have no band4 connected. here is my battery report. check my screen on time 8 hours and I was able also to push another 30 minutes with that 11% remaining
    Zoide likes this.
  9. jimmmysil likes this.
  10. jimmmysil
    I don't play games on my phone but yeah games of course are heavy and drain your battery but still check your battery usage, the information you need are there.
  11. chubs12
    Gingerbread May 2, 2020
    chubs12 , May 2, 2020 :
    Single sim sim and how often connected to WiFi?
    SiberianTiger74 and jimmmysil like this.
  12. Iam ironman
    Froyo May 2, 2020
  13. jimmmysil
    I have only one sim yes. I have data and wifi on all the time. Right now cause of the lockdown wifi is let's says at about 70% of my usual usage and a 30% data.
  14. MirceaForce
    MirceaForce , May 2, 2020 :
    is your sim at least 2019 ? if not please change with new one of 2020, you have to ask them in the store if the new sim is from batch 2020 if not, also call them you have to had enabled 5g subscription form digi operator, because the phone must work on all networks.
  15. ayan1mandal
    Donut May 2, 2020
    ayan1mandal , via OnePlus 8 Pro , May 2, 2020 :
    After this update yesterday (UK variant
    ), Widevine DRM is reported as L3. Netflix only playing SD. I used DRM Info app, to verify. It also reports L3.
    Anyone else facing the same?
  16. KAKAZUYA
    Cupcake May 2, 2020
    KAKAZUYA , via OnePlus 8 Pro , May 2, 2020 :
    Do you guys have a "weird" experience with the pro color mode feature (it's the feature that boosts the contrast and saturation when you play a video in full screen)?
    I've noticed the opposite effect (video less saturated, skin tones whitish, a bit more contrast but not attractive probably) on build 10.5.4.
    Thanks everyone!
    B1587637663881 likes this.
  17. E1586881563062
    Cupcake May 2, 2020
    E1586881563062 , via OnePlus 8 Pro , May 2, 2020 :
    can anyone give me reply, how is latest update 10.5.6 for one plus 8 pro
    if it another piece of crap than 10.5.5 I am done I don't install that crap on my phone
    the battery life is really amazing when it come with built in is, after that I installed two updates, when I seen improvement and stability fixes
    battery life became worst, and causing over heating problems while charging and playing games,
    my phone is not using location services enabled all the time, and they are restricted only to use while we use such apps, and never installed what's app and other platforms phone is currently only being tested with PUBG game life and standby battery life
    and everything changed within two updates and turned worst
    Dear one plus if you cannot fix front camera errors, battery life and battery over heat problems
    could you please allow us to revert back to original os version received with the phone?
    thank you
    regards
    sudheer
  18. L1586880784848
    Cupcake May 2, 2020
    L1586880784848 , via OnePlus 8 Pro , May 2, 2020 :
    I can confirm that there are still battery related problems with 10.5.6IN11BA.
    I upgraded today directly from 10.5.4, after the update expected battery life dropped from greater 1 day to approx. 10 hours.
    I also experienced another strange thing just now: I have charged my phone to 100% and used it for approx. 20min: 96% battery and 10hours remaining. I then performed a restart. After the restart the battery showed still 96% but usage data not available and time since last full charge 0 min.
  19. halo86
