Oxygen OS vs Color OS via OnePlus 8T
  1. Prince4568
    Cupcake Jan 27, 2022
    Prince4568 , via OnePlus 8T , Jan 27, 2022 :
    How can u take away that one single thing for which your brand was famous for ?
    I mean who will buy OnePlus phones now if they don't have Oxygen OS? I was planning to buy 10 series but I won't after seeing this downgrade in the OS department
    Had so many expectations from OnePlus but all did they is CHOKE
    I will either buy iPhone 12/13 or switch to Samsung Flagships
    Or Realme (Because they atleast have an App drawer)
    Hehe🥶🤣🤣🤣🤣🤣🤣
    SoumyaNC likes this.
  2. ghostofcain
    Marshmallow Jan 27, 2022
    ghostofcain , Jan 27, 2022 :
    Give them a chance this is the first iteration of the new OS, yes it's a little rough and ready but first releases often are.
    If you think you're issues are going to be solved by swapping to the most restrictive mobile OS around, then be my guest.
    BTW OOS12 has an app drawer, unless YOU'VE configured it without one.
    Aaron2017 likes this.
