Oxygen Updater shows bug, How can i fix this problem..? via OnePlus 7T
  1. Q1611826617966
    Eclair Apr 23, 2021
    Q1611826617966 , via OnePlus 7T , Apr 23, 2021 :
    Caoimhín likes this.
  2. Aaron2017
    KitKat Apr 23, 2021
    Best Answer
    Aaron2017 , Apr 23, 2021 :
    There are more 7t users who's buildnumber was unknown after the first OS11 update. Did you turn on advanced mode in Oxygen updater? If you select full update after that, you should be able to download it
    J4t1np4r3kh, Bobbie63 and Caoimhín like this.
  3. Caoimhín
    OnePlus 9 Series Expert Community Expert Apr 23, 2021
  4. Q1611826617966
    Eclair Apr 23, 2021
    Thank you so much for your kind reply. I have put phone details below⬇, Thank you.
  5. Q1611826617966
    Eclair Apr 23, 2021
    I have updated my OP-7T to Android 11 via oxygen updater but the build number showing unknown. I am confused wherever i have update a genuine system or it's not in advanced level.
  6. Caoimhín
    Caoimhín , via OnePlus 6T , Apr 23, 2021 :
    I can see the issue, your build number is unknown, so Oxygen Updater can't check which version you are on.
    Also you have the HD1907 variant, which was originally a TMobile carrier phone.
    https://en.wikipedia.org/wiki/OnePlus_7T?wprov=sfla1
    Are you on TMobile or has the phone been converted to an international version?
    Where did you install the last update from?
  7. Q1611826617966
    Eclair Apr 23, 2021
    No, I am not using T mobile. I have a little knowledge about T mobile but i have been using my own country sim for last 3 month without any disturbance. I have updated Android 11 from Oxygen updater two days ago.
  8. Caoimhín
    Just a query, did you buy the phone on the second hand market?
    Bobbie63 and Aaron2017 like this.
  9. Q1611826617966
    Eclair Apr 23, 2021
    I am not concerned about that. I have checked activation number after buying the phone and it's similar to the day i have bought the phone from the shop.
  10. Caoimhín
    The reason I ask is because a lot of US TMobile phones which have been converted to global variants have hit the second hand markets around the world. The Bootloader on these variants are different to the Global version and can cause some issues such as you see there now.
    With Android 11 security now tightened from previous versions this can have unknown consequences. So when the third party app such as Oxygen Updater attempts to update it may no longer have the necessary permission to view the Build number and you now get the issue you are currently seeing.
    Here is a forum on XDA with the same issue as you.
    https://forum.xda-developers.com/t/...to-say-unknown-in-the-android-11-rom.4255803/
    Currently there is no solution. But keep an eye on XDA and converted TMobile OnePlus 7T phones, they may find a workaround.
  11. Q1611826617966
    Eclair Apr 23, 2021
    I am so disappointed after hearing this.. what can i do now, I am feeling guilty to update it into Android 11. previous 10 was better for me where build number and everything showing as it a normal impression of activated system.
  12. Q1611826617966
    Eclair Apr 23, 2021
    Thank you so much, I am so grateful to you. I appreciate the way you replied compromising your loss of important time..thank you..!
  13. Caoimhín
    Yes, Android 10 had less security features to allow continuous updates, only way around it possibly would be to download the file from a direct link, from XDA or another source and Manually install them. See if that will work for you.
    This is a repository of links for the 7T, has 3 versions. If yours is global, have pointed to the Global zip files in the image below.
    https://forum.xda-developers.com/t/oneplus-7t-rom-ota-oxygen-os-repo-of-oxygen-os-builds.3997037/
    J4t1np4r3kh, Bobbie63 and Aaron2017 like this.
  14. Caoimhín
    You're welcome, hope the suggestion above works out. Please do let us know if it does, as it may help others in the future.
  15. Q1611826617966
    Eclair Apr 23, 2021
    yes, i turned it to the advanced. What should I do after that.
  16. Q1611826617966
    Eclair Apr 23, 2021
    I didn't get it.
  17. Aaron2017
    KitKat Apr 23, 2021
  18. Caoimhín
    Bobbie63 and Q1611826617966 like this.
  19. Q1611826617966
    Eclair Apr 23, 2021
  20. Aaron2017
    KitKat Apr 23, 2021
    You should be able to see the update ready to download on the first screen of the app
