631
OxygenOS 10.0.0 for the OnePlus 5 and 5T
  1. Petya_82
    Gingerbread Jun 1, 2020
    Petya_82 , via OnePlus 5T , Jun 1, 2020 :
    You can fix it only through the SetEdit application. Change the value of "1" to "0" and there will be old gestures.
  2. G_Karan_Goyal_TZlf , via OnePlus 5 , Jun 1, 2020 :
    Recording play feature is not working properly. Voice is not clear when we play a call recording. I restarted my device too then also not working properly.Solve it ASAP
  3. vishal.verma
    Cupcake Jun 1, 2020
    vishal.verma , via OnePlus 5T , Jun 1, 2020 :
    PLEASE tell the steps to make shift the gesture based back move from side edges to bottom edge...as was their before update to Android 10 for one plus 5T
  4. vishal.verma
    Cupcake Jun 1, 2020
  5. Petya_82
    Hello! Yes, I use this application, not the first day, everything works like on 9 Android. ;)
  6. eraery97
    Donut Jun 1, 2020
  7. azlan0116
    Donut Jun 1, 2020
  8. eraery97
    Donut Jun 1, 2020
    eraery97 , Jun 1, 2020 :
    well i have a question........when i open factory test and testing flashlight, it's working but in notification panel it's greyed out why?
  9. Petya_82
  10. eraery97
    Donut Jun 1, 2020
    white topic? didn't understand bro...
  11. Photographyeyecatching
  12. Petya_82
    Logs in animation, in the system ... ???
    • If after installing from 9 to 10 the android has some kind of lags in the system, not smooth animation and the like ... try resetting the smartphone to the factory settings. It helped me in some cases.
    • If the applications in the Play Market are not updated, or there are crashes in the applications, try in settings / applications / clear cache / clear storage / stop the application.
    This applies to both the Play Market and other applications, such as Chrom and so on ...
    • But the battery really discharged quickly and discharges after updating to 10 Android, now you have to charge it more often with the same everyday use of your smartphone as with 9 ...
    Now, as on the iPhone, it’s constantly necessary to charge.
    On Android 9 it was much better.
  13. Rowdy Harish
    Cupcake Jun 1, 2020
  14. ArvindSinghK
    Cupcake Jun 1, 2020
    ArvindSinghK , via OnePlus 5T , Jun 1, 2020 :
    does it update also for beta user i m using beta3 in 5t device..
    if it's also for beta user then still m not getting any update..
    provide solution.
  15. Petya_82
  16. eraery97
    Donut Jun 1, 2020
    still flashlight is unclickable(already tried)
  17. ALFI.7
  18. ALFI.7
    ALFI.7 , via OnePlus 5T , Jun 1, 2020 :
    I've kept the Assistant option off but it keeps on asking. i just want the whole bottom swipe up option to be for home button.
    Petya_82 likes this.
  19. G1537874823242
    Donut Jun 1, 2020
    G1537874823242 , Jun 1, 2020 :
    Call recorder not working properly after stable android 10 update please fix and recognize this issue... Oneplus 5t
  20. Marleyfan61
    Froyo Jun 1, 2020
    Marleyfan61 , Jun 1, 2020 :
    I think his point is that while many are having some issues, many are not. I would suspect that most who update and don't have any problems don't jump on here and talk about the problems they're not having.
    jlmfrance76 and 350Rocket like this.
