628
OxygenOS 10.0.0 for the OnePlus 5 and 5T
  1. AtharvPatole
    Cupcake Jun 1, 2020
    AtharvPatole , via OnePlus 5 , Jun 1, 2020 :
    The phone speed has slowed down after the update
    Camera pictures quality has become worst after the update
    Battery draining out fast after the update
    The time required for opening the app is about now 3-4seconds
    Wi-Fi is disconnecting automatically even in strong network
    Bluetooth is not connecting to the car
    The space between lower border screen & lower app tray is too much
    @OnePlus please fix the issues...the phone in android 9 was best but now in android 10 it has become worst
  2. AtharvPatole
    Cupcake Jun 1, 2020
    Yes. The space between lower border of screen & Lower tray app is increased
    FredericoMaia likes this.
  3. Ashwin Angadi
    Eclair Jun 1, 2020
    Ashwin Angadi , Jun 1, 2020 :
    Hello, Is there any way to enable VoWiFi on OP5? As iam using both Jio & Airtel and also jio fiber, so VoWiFi is the most needed feature to use jio fiber fixed line on jio call app. Thanks in advance.
  4. Petya_82
    Gingerbread Jun 1, 2020
    Petya_82 , via OnePlus 5T , Jun 1, 2020 :
    The gap for everyone is like - what's the problem? And it always seemed like - a space for gestures. I’m more embarrassed by the upper gap, where you can put a number of badges, honestly I don’t remember if that was before. ) Go clean up can the application for games / cache / storage / disconnect, reboot the device.
  5. Sid_Ck
    Ice Cream Sandwich Jun 1, 2020
  6. k.ambuj
    Donut Jun 1, 2020
  7. jsbothra
    Eclair Jun 1, 2020
    jsbothra , via OnePlus 5T , Jun 1, 2020 :
    AAC bluetooth codec is not working after update.
    Q1527420442516 likes this.
  8. Frakkien!
    Cupcake Jun 1, 2020
    Frakkien! , via OnePlus 5T , Jun 1, 2020 :
    Wow! So I can no longer use my phone while driving (nor with Sync 3 (Ford) or Android auto). Hope it will be fixed soon...
  9. rohanjain99
    Eclair Jun 1, 2020
    rohanjain99 , Jun 1, 2020 :
    I'll asked OnePlus either to remove your wifi calling or give me the same ..[e]1f602[/e][e]1f44d[/e]
  10. jsbothra
    Eclair Jun 1, 2020
    i just bought Oneplus Bullets Wireless Z and they supported AAC for better audio quality and low latency, after the update they don't sound as good! they will definitely fix this because this isn't something that can be left out, it is a major issue with most of the cars and many earphones.
    I've sent them bug report with logs. hopefully the next update comes fast and fixes this.
  11. peter selvam
    Cupcake Jun 1, 2020
    peter selvam , via OnePlus 5T , Jun 1, 2020 :
    after update OS 10 my ringtone volume will be automatically reduced when I took my phone and wallpaper theme also automatically changed any one facing this problem kindly tell me the solution
  12. Abdul Karim Shaikh
    Cupcake Jun 1, 2020
    Abdul Karim Shaikh , Jun 1, 2020 :
    OP 5 updated with OS 10 but connection doesn't switch to Mobile data when Wifi is connected without Internet.
    Any setting to change or is this a known behaviour?
    Thanks.
  13. BeardyBiceps
    rohanjain99 likes this.
  14. ashish.ghule1
    Cupcake Jun 1, 2020
    ashish.ghule1 , Jun 1, 2020 :
    They were supposed to make few changes in the network settings in op5. As if now I m operating on Android 10 and it just shows 2g/3g/4g but they don't have any option for just LTE or 4G as other mobile companies give the separate options for better connectivity.. one plus should consider this to make the change and make it only LTE or 4g..I hope it will help for better connectivity. Any suggestions are mostly welcome...
  15. Harish kiddy
    ArvindSinghK and AtharvPatole like this.
  16. T1591026305440
    Cupcake Jun 1, 2020
    T1591026305440 , Jun 1, 2020 :
    Salve, avendo fatto l'aggiornamento 10.0,con la app oxygen updater, posso cancellare da memoria locale o devo lasciarlo?
  17. ashish.ghule1
    Cupcake Jun 1, 2020
  18. ashish.ghule1
    Cupcake Jun 1, 2020
    Go to the phone application, then in the upper right corner click (three dots) - phone settings. Go to the sounds and vibration section, there is your problem, turn it off and everything will be fine. Give it a try.
  19. ashish.ghule1
    Cupcake Jun 1, 2020
  20. Fahad Mehedi
    Cupcake Jun 1, 2020
    Fahad Mehedi , via OnePlus 5 , Jun 1, 2020 :
    I am using One plus 5.
    I have install the beta version manually as you suggested.
    Could you please tell us that stable version will come or not.
    because I have heared from my friend he is using one plus 5t he have recieved stable version for android 10.
    please let us know android 10 stable we will recieve updates or not?or we still need to update manually.
