634
OxygenOS 10.0.0 for the OnePlus 5 and 5T
  1. F_Nitesh_Kunwar_zlHB , via OnePlus 5 , Jun 1, 2020 :
    why sometimes mobile data connection gets off automatically , i have been facing OS10 update, i have to manually switch it On and sometimes ur sim slot 2 network bar show no sim card .
    Is there anyone else facing the same kind of issues?.
  2. priiitttt
    Cupcake Jun 1, 2020
  3. Laki Shetty
    Honeycomb Jun 1, 2020
    Laki Shetty , via OnePlus 5 , Jun 1, 2020 :
    I think, it's time to rethink for all those morons who backed oneplus while releasing worthless beta updates. Beta updates seems far superior than the current stable version.
  4. nirajkagarwal93
    Cupcake Jun 1, 2020
  5. osterlindh
    Froyo Jun 1, 2020
    osterlindh , Jun 1, 2020 :
    Wtf oneplus... Why remove The best gestures? My girlfriend is Not happy now.. Aaaaaaaaaaah
  6. Petya_82
    Gingerbread Jun 1, 2020
    Petya_82 , via OnePlus 5T , Jun 1, 2020 :
    You can fix it only through the SetEdit application. Change the value of "1" to "0" and there will be old gestures. It is unlikely that the old ones will be returned, but we hope that at least they improve the new ones - for the most part of the display and sensitivity.
    Kausthubha likes this.
  7. Petya_82
    make the girl happy, install the SetEdit app and return her gestures. I think she will thank you 2 times minimum))) Look, I posted screenshots next to your post on how to make it.
    djaxxo likes this.
  8. rohitgulati14
    Cupcake Jun 1, 2020
    rohitgulati14 , Jun 1, 2020 :
    I have one plus 5 model and I am currently on beta 35 version of Android 9. and till now i didn't receive the update option. do I have to install manually or i will get it in near future?
  9. Flash1593
  10. Flash1593
    Flash1593 , via OnePlus 5 , Jun 1, 2020 :
    I have updated my OnePlus 5 with Android 10 and having no issues. Running very smoothly as I have enabled the new gestures which are very fast and smooth. So I don't think there is any serious issue with the update.
    Marleyfan61 likes this.
  11. Ajinx_Kale
  12. rvirex
    rvirex , via OnePlus 5 , Jun 1, 2020 :
    How does it matter or affect your experience?
    FP sensor is still there, isn't it?
    don't afraid of minor changes here and there, look for serious bugs or actual problems instead of nitpicking 🤔
    I hope you can understand my point.
    priiitttt and Petya_82 like this.
  13. voliantcargo
    Cupcake Jun 1, 2020
    voliantcargo , via OnePlus 5T , Jun 1, 2020 :
    I do not have the vowifi or the call recording, what happens with that, some error because I have seen that some devices are and others are not.
  14. Andrew Bond
    Cupcake Jun 1, 2020
    Andrew Bond , Jun 1, 2020 :
    Yes, if I have the alert slider up and mute media ticked in settings I can still here music playing. I'm sure that didn't happen with Pie.
  15. voliantcargo
    Cupcake Jun 1, 2020
  16. VASILIS ZORMPAS
    Eclair Jun 1, 2020
  17. bharat_trouper
  18. Petya_82
    what is the problem? The OnePlus launcher is already available on the Play Market.
  19. Sid_Ck
    Ice Cream Sandwich Jun 1, 2020
  20. Cris_Ferreire
    Froyo Jun 1, 2020
