634
OxygenOS 10.0.0 for the OnePlus 5 and 5T
  1. M1518052563915
    Cupcake Jun 1, 2020
  2. MrKulkarni
    Honeycomb Jun 1, 2020
    MrKulkarni , Jun 1, 2020 :
    Go to One Plus Launcher in Apps and click on Advanced, scroll down and you'll find the version at the bottom of the page.
  3. V1591039066059
    Cupcake Jun 1, 2020
    V1591039066059 , Jun 1, 2020 :
    i updated to Android 10.0 yesterday since then i am facing issue with slider to flick between ring vibrate n silent i tried changing it by moving the slider it doesn't work n the phone is always in silent mode now even i cannot change this by going into settings please help
  4. suryachi
    Cupcake Jun 1, 2020
    suryachi , Jun 1, 2020 :
    im also facing this for past 8 months
  5. 7359949392
    Donut Jun 1, 2020
  6. M1584446496435
    Cupcake Jun 1, 2020
    M1584446496435 , Jun 1, 2020 :
    Minor bug: Bluetooth earphones (Galaxy buds+) don't connect automatically when phone Bluetooth is turned on. in short - phone doesn't actively try to connect to last known connected device.
  7. manish.ecol
    Cupcake Jun 1, 2020
    manish.ecol , via OnePlus 5 , Jun 1, 2020 :
    Does anyone having issue with split screen gesture?
    I have set the settings on split screen gesture on double tap of home button but it doesn't work as double tap results in home.
  8. fazerboy0_3
    fazerboy0_3 , Jun 1, 2020 :
    Mines fine apart from android auto
  9. Stirlin2001
    Gingerbread Jun 1, 2020
    Stirlin2001 , via OnePlus 5T , Jun 1, 2020 :
    Trusted location keeps stopping working.
    The usual fix (turn off trusted agent, reboot, turn back on) seems to fix it.
    anyone else found this?
  10. fazerboy0_3
    WiFi calling working uk on 3 for. Me
    andykyriacou48 likes this.
  11. fazerboy0_3
    Why update on day 1 then wait too see what bug's people report. Or are you like the rest that moan they want newest version then. Complain on day 1 of release. Just learn to wait a few day's see if any bug reports. Did you do ota update or Oxygen downloader
  12. Harish kiddy
    Harish kiddy , via OnePlus 5T , Jun 1, 2020 :
    Why refresh button was seen some areas this isan bug just like this image please find above the clock too lag and many apps crashing I have freshly installed this update but many issues lagging need a fix on next update
  13. krishnandusarkar
    Eclair Jun 1, 2020
  14. Omar5T
    Omar5T , via OnePlus 5T , Jun 1, 2020 :
    does not it revert to the default after the fone restarts....u have to again redo it after every time....did u check that?
  15. Petya_82
    Petya_82 , via OnePlus 5T , Jun 1, 2020 :
    so what is the mistake then? Well, there was an icon at the bottom, now at the top, what's wrong?
  16. Harish kiddy
  17. Petya_82
    I personally use this application, everything works well, without complaints. There are no crashes, and after rebooting the phone too. Gestures as in 9 android. At the expense of other functions of this application, I do not know how they work, but for gestures, what you need!
  18. Silver_
  19. Petya_82
    and in order to return to new gestures, you just need to enable the installed OnePlus gestures in the phone settings. And you do not need to prescribe anything in the SetEdit application, only during installation, change "1" to "0".
  20. Petya_82
    I agree and the screen split is more conveniently located when you click on the tab. And I also liked the function of deleting the inscription of icons, now there is no need to do this manually with each application
