522
OxygenOS 10.0.0 for the OnePlus 5 and 5T
  1. mangeshshinde03
    Cupcake Jun 2, 2020
    mangeshshinde03 , Jun 2, 2020 :
    still not received the update still waiting for the update
    Thank you OP Team for this update #NeverSettle [e]1f44d[/e]
  2. indrajit4
    Honeycomb Jun 2, 2020
    indrajit4 , via OnePlus 5 , Jun 2, 2020 :
    go to call settings and sound settings in there, try disabling ascending ringtone option.... the ring volume starts from lower ringtone and increases eventually
  3. G_murtaza_badri_VgfJ
    Donut Jun 2, 2020
    G_murtaza_badri_VgfJ , Jun 2, 2020 :
    there is no ascending option can you have a screenshot
  4. indrajit4
  5. Silver_
    Gingerbread Jun 2, 2020
    Silver_ , via OnePlus 5T , Jun 2, 2020 :
    okay. but both of the things you mentioned earlier were already there. 😛
    the just moved the split screen option to long press instead of the three dots earlier
    and closing all all's was already present in the form of an x mark below the apps which is now present as a button
  6. G_murtaza_badri_VgfJ
    Donut Jun 2, 2020
  7. R1512986839130
    Cupcake Jun 2, 2020
  8. Sid_Ck
    Ice Cream Sandwich Jun 2, 2020
  9. shr3yan5
    Cupcake Jun 2, 2020
    shr3yan5 , Jun 2, 2020 :
    Thanks OP for adding the Call recording option in OP5. I have noticed a problem while playing the recorded call. The recorded call sounds like loosing tempo. It sounds like slurred or sluggish. Feels like the audio playback isslowed down. Did anyone notice this problem?
    Thank You.
  10. Ksandesh
    Cupcake Jun 2, 2020
    Ksandesh , via OnePlus 5 , Jun 2, 2020 :
    every now and then my phone's volume becomes low(although it's full in settings) and corrects after restarting since this update
  11. Robert Uszok
    Froyo Jun 2, 2020
  12. Animeshkar15
    Froyo Jun 2, 2020
    Pratim_Das_Gupta likes this.
  13. G1522267572926
    Cupcake Jun 2, 2020
  14. Pratim_Das_Gupta
    Froyo Jun 2, 2020
    Pratim_Das_Gupta , via OnePlus 5 , Jun 2, 2020 :
    In the log kit the option is not at all available now.
  15. T1525172988231
    Cupcake Jun 2, 2020
  16. rishiraj007
    Cupcake Jun 2, 2020
    rishiraj007 , via OnePlus 5 , Jun 2, 2020 :
    Update is causing issues within certain apps like karaoke apps like starmaker while switching between broadcasting to taking calls. Could you please check on it.
  17. N1578460185958
    Cupcake Jun 2, 2020
    N1578460185958 , via OnePlus 5T , Jun 2, 2020 :
    damned it haha its hard to get 5hrs sot on android 10 the battery drain too fast how to resolve this🤣🤣🤣🤣🤣how to calibrate the battery guys?
    Harry d best likes this.
  18. PokiX
    Jelly Bean Jun 2, 2020
    PokiX , via OnePlus 5T , Jun 2, 2020 :
    Updated thanks for the work.
    Glad we can edit the prop for restoring old gesture.
    Are there any side effects? Why was it removed in the first place with no option to choose?
