574
OxygenOS 10.0.0 for the OnePlus 5 and 5T
  1. karanverma_archi
    Cupcake Jun 2, 2020
    SudebCena likes this.
  2. Petya_82
    Gingerbread Jun 2, 2020
    Petya_82 , via OnePlus 5T , Jun 2, 2020 :
    Hello! Only gestures, like at 9.
  3. V1591039066059
    Cupcake Jun 2, 2020
    V1591039066059 , Jun 2, 2020 :
    not been able to keep phone on ringing cannot adjust the ring volume since the recent Android 10 update please guide tried many things like reset network n all but nothing helped the phone is always on mute n there is no way i can change it even slider on left of OnePlus 5 has stopped working
    sreekeshd likes this.
  4. Petya_82
    Faced such a problem. While in the "community" application, the display suddenly began to flicker in red. I went into the google application this was not. returned to the community, the display also flickered for a while, then stopped. Has anyone encountered such a problem? What is the reason for this? Is this incorrect application of the "community" or incorrect update of Android 10?
  5. kishan nishad
    Donut Jun 2, 2020
  6. nikhil konde
    Cupcake Jun 2, 2020
  7. slavekt
    Cupcake Jun 2, 2020
    slavekt , Jun 2, 2020 :
    Do you know if the developers read this forum and will fix the reported issues? I'd like to update, but not to this buggy version.
  8. mennovanrijn
    Cupcake Jun 2, 2020
  9. LordPain
    Eclair Jun 2, 2020
    LordPain , via OnePlus 5T , Jun 2, 2020 :
    Thank you so much for the update! Only OnePlus could provide their users with the latest Android 3 years prior to the release. Kudos to the team [e]1f44f[/e]
    The UI is brilliant and the OS is very smooth in general. Only issue I'm still facing is screenshot editing. When I take a screenshot and open it in gallery to edit it, it takes ages to load. Really frustrating to me - it was there in the previous versions as well. Can I change the default app for this? Or any fix?
    Cheers.
  10. rohanjain99
    Eclair Jun 2, 2020
    rohanjain99 , Jun 2, 2020 :
    Space between Icon is a feature of android 10 so it is not a bug and if you don't want gaming mode then remove that game from game space
  11. rohanjain99
    Eclair Jun 2, 2020
    I'll suggest you to wait a little more , It will be there.
  12. rohanjain99
    Eclair Jun 2, 2020
    Wait it will be there in few days ..it is a process which is rolling out , wait you will get it.
  13. T1525172988231
    Cupcake Jun 2, 2020
    T1525172988231 , Jun 2, 2020 :
    thanks buddy
    rohanjain99 likes this.
  14. ashish.ghule1
    Cupcake Jun 2, 2020
    ashish.ghule1 , Jun 2, 2020 :
    Go to call log setting, click on 3 dots. U will get option of sound and vibration. In that just turn off the option of Raise to lower ringtone. Your problem will be 100% fixed.. thanks me later 😜
  15. ashish.ghule1
    Cupcake Jun 2, 2020
  16. V1591039066059
    Cupcake Jun 2, 2020
    i wud love to thank you but still the issue is not been resolved phone is still on mute n cant change it
  17. I1586840528190
    Cupcake Jun 2, 2020
    I1586840528190 , Jun 2, 2020 :
    Yes there are issues with the notification settings
  18. Tanwarpuneet1991
    Cupcake Jun 2, 2020
    Tanwarpuneet1991 , Jun 2, 2020 :
    slow dash charging after update . Updates are meant to improve performance but you are making the device worse after every update . Making devices slow through updates and forcing people to buy new
  19. A1591090564368
    Cupcake Jun 2, 2020
    A1591090564368 , Jun 2, 2020 :
    I have a ONEPLUS 5.
    I upgraded to Oxygen 10.
    since then, the right bottom Button for displaying
    ALL OPEN WINDOWS. has stopped working.
    PLEASE HELP.
    URGENT PLEASE
    KIRAN JOSHI
    M +91 9937013666
  20. X1515856179524
    Donut Jun 2, 2020
