634
OxygenOS 10.0.0 for the OnePlus 5 and 5T
  1. saiganeshctk
    Cupcake Jun 10, 2020
  2. Sid_Ck
    Ice Cream Sandwich Jun 10, 2020
    Sid_Ck , Jun 10, 2020 :
    Pretty strange New A10.0.0 build is Live but with the same version, I thought hotfix builds used to have new version nos.
  3. PokiX
    Jelly Bean Jun 10, 2020
    PokiX , via OnePlus 5T , Jun 10, 2020 :
    Forgot to look at baseband version on previous A10 to see if it changed.
    Someone still having the first build can share the BB version?
    In attachement the new one.
    I'm surprised we're still on April security patch? Can't remember update period for that.?
  4. Variola major
    Variola major , via OnePlus 5T , Jun 10, 2020 :
    Did you get the OTA or Oxygen Updater? Which country? Belgium over here :)
  5. carloraudino
    Eclair Jun 10, 2020
  6. cristi_lazar
    Donut Jun 10, 2020
  7. S1591819217963
    S.k.krishnan likes this.
  8. NofanTasi
    NofanTasi , Jun 10, 2020 :
    so : then what is latest build number ?
  9. krishnandusarkar
    Eclair Jun 10, 2020
    krishnandusarkar , via OnePlus 5T , Jun 10, 2020 :
    Still using the first build. Does this help?
    PokiX likes this.
  10. Chiel
    Froyo Jun 10, 2020
    Chiel , Jun 10, 2020 :
    I just installed the hotfix but wonder what it fixed.
    Maybe the screen not responding after charging which was temporarily 'fixed' by setting the screensaver on never.
    Would have been nice to get a full list of fixes.
  11. flipside
    Donut Jun 10, 2020
    flipside , via OnePlus 5 , Jun 10, 2020 :
    5 is 3 years in 10 days
  12. batysta
    Donut Jun 10, 2020
    batysta , Jun 10, 2020 :
    I solved all my problems after updating to android 10.
    I downgraded to android 9. I am happy now. Thank you OnePlus.
  13. PokiX
    Didn't get any of the two builds with OTA. So I used Oxygen Updater. France here, salut ;)
  14. jontalk
    jontalk , Jun 10, 2020 :
    Wow...don't think I've seen this many issues reported for previous OS updates though from experience MOST problems stem from third party apps rather than the update. That said, releasing a build with no other gesture options is lame since the 5T display is different from the 6, 7, and 8. We haven't received 10.0 in the US yet, so I suspect OP is working on another build. PLEASE send bug reports and feature feedback to support
  15. carloraudino
    Eclair Jun 10, 2020
  16. batysta
    Donut Jun 10, 2020
    After the irritating experience with this android 10
    I just roll back to 9.
    NOTE: This process will WIPE the entire data on your phone. Before proceeding, make sure you’ve taken a backup of your important data and your phone is charged.
    Downgrade from Android 10 to Android 9 (OnePlus 5T):
    1 - Download OxygenOS 9:
    https://oxygenos.oneplus.net/OnePlus5TOxygen_43_OTA_054_all_2002242025_81ae0ff9d1c34a3f.zip
    2 - Move the downloaded file “OnePlus5TOxygen_43_OTA_054_all_2002242025_81ae0ff9d1c34a3f.zip” to the root.
    3 -Boot into Stock Recovery – To do so, power off the phone. Then press the power button and volume down key simultaneously to boot into recovery.
    4 - Select language > Wipe data and cache > Reset system setting > Yes. Then select done.
    5 - Now select “Install from internal storage” and select the zip file downloaded in step #1.
    6 - After installation is complete, go back to “Wipe data and cache” and tap “Erase everything”.
    7 - Then go back and “wipe cache”.
    8 - Reboot​
    Be Happy!
  17. Some_Random_Username
    Community Bug Hunter Jun 10, 2020
    Some_Random_Username , Jun 10, 2020 :
    Baseband is same version as on 200513 build, see https://github.com/oxygen-updater/b...1e145cdf8dcf450511ada/op5t/10.0.0.getprop#L63
    Nevermind, you were already answered, didn't notice
    Security updates are normally meant to be bimonthly, but I think OP is focusing at fixing bugs specific to our device instead of caring about security patches (which needs to be tested again OOS customizations) for now
    PokiX likes this.
  18. echosen
    Eclair Jun 11, 2020
    echosen , Jun 11, 2020 :
    Is that the only significant difference?
  19. nhvs
    Cupcake Jun 11, 2020
    nhvs , via OnePlus 5T , Jun 11, 2020 :
    thank you , I have tried but because I was in the open beta they tell me I have to recovery reboot which would wipe the device. I'd rather avoid that. if you have a workaround I'd be thankful
  20. PSSF23, NofanTasi and nhvs like this.
