634
OxygenOS 10.0.0 for the OnePlus 5 and 5T
  1. Ajinx_Kale
    Gingerbread Jun 14, 2020
  2. vivek_chavan
    Eclair Jun 14, 2020
    vivek_chavan , via OnePlus 5 , Jun 14, 2020 :
    Got the OTA finally for OP5.. Anyone with this spacing ?
    The my entire set of icons can fit in that space. Same in the above as well.
    Let me know if anyone else has this or its just me.
    Just letting you guys know I use hardware navigation buttons. So I feel this spacing is buggy.
  3. ashu_ashwin11
    Cupcake Jun 14, 2020
  4. Manjitenu
  5. sheikh shoaib
    Froyo Jun 14, 2020
  6. Pravesh Popli
    Pravesh Popli , Jun 14, 2020 :
    You can still access it from one plus log kit just by dialing *#800#
    But yes they should include it in latest update
    aakashsood likes this.
  7. rasulkhan7
  8. aakashsood
    Jelly Bean Jun 14, 2020
    aakashsood , via OnePlus 5T , Jun 14, 2020 :
    Pravesh Popli
    But yes they should include it in latest update​
    Yeah I did it as soon as the update arrived but I guess they were right in removing it. 😛 Vowifi is not stable at all and most of the times I see it switching between volte and Vowifi. maybe they are rectifying it before it gets released to the masses. I have a OP7T too in my household and Vowifi works like a charm on it.
    NShankaraN likes this.
  9. aakashsood
  10. Wilhelm69
  11. Wilhelm69
    Wilhelm69 , via OnePlus 5T , Jun 14, 2020 :
    That is impossible. It's nit removed.
    Try reboot device if it doesn't help, factory reset phone
  12. hjs2396
    hjs2396 , via OnePlus 5T , Jun 14, 2020 :
    which launcher version are you using
    abdis the bottom bar active or hidden
  13. hjs2396
    download latest version of oneplus logkit from apk mirror
    and then go to *#800#* - logkit - function switch - vowfi switch
    sheikh shoaib and F1590942291006 like this.
  14. vivek_chavan
    Eclair Jun 14, 2020
    I am using OnePlus launcher.. I use the hardware touch for navigation. which means the on screen navigation is disabled.
  15. hjs2396
    i am on the new hotfix version and i have the option
  16. hjs2396
    which version of launcher are you using
  17. Wilhelm69
  18. vivek_chavan
    Eclair Jun 14, 2020
  19. rKarthik1992
  20. hjs2396
    okay try updating it with 4.5.2 from apk mirror and see if it helps
