634
OxygenOS 10.0.0 for the OnePlus 5 and 5T
  1. KNIGHTxOP
    Cupcake Jun 14, 2020
  2. KNIGHTxOP
    KNIGHTxOP , Jun 14, 2020 :
    I updated my one plus 5 today and after that I can't see my photos and videos in galaxy and play store also crashes constantly
    Can anyone tell me how I can downgrade my Phone to the old version
  3. vivek_chavan
    Eclair Jun 14, 2020
    vivek_chavan , via OnePlus 5 , Jun 14, 2020 :
    hjs2396
    okay try updating it with 4.5.2 from apk mirror and see if it helps
    tried updating to 4.5.2.. no luck..
    can you tell me what is the latest version of camera app for OnePlus 5
  4. aakashsood
    Jelly Bean Jun 14, 2020
    aakashsood , via OnePlus 5T , Jun 14, 2020 :
    Factory reset isn't the answer to every problem. There are many other options that can be taken before the person decides to factory reset the device.
  5. Wilhelm69
    Gingerbread Jun 14, 2020
    Wilhelm69 , via OnePlus 5T , Jun 14, 2020 :
    It works.... i got call recording settings and call recording option back after factory reset
  6. Manjitenu
    Manjitenu , via OnePlus 5 , Jun 14, 2020 :
    I am not getting updates. Is this due stage uploading or my beta. I am on Beta 35 Android 9. Will I gets update thru OnePlus.
    or I need to roll back to stable, then I will get it
  7. B1590589417554
    Eclair Jun 14, 2020
    B1590589417554 , Jun 14, 2020 :
    U need to roll back on the stable channel in order to get the OTA
  8. T1591969610126
  9. UNG_mohamad_saad
    Eclair Jun 14, 2020
  10. NShankaraN
    Ice Cream Sandwich Jun 14, 2020
    NShankaraN , via OnePlus 5 , Jun 14, 2020 :
    exactly .. even if the WiFi calling is enabled , it is very unstable and swithches frequently between VoLTE and VoWiFi.
    Hopefully it will be rectified in upcoming releases
    aakashsood likes this.
  11. Sid_Ck
    Sid_Ck , Jun 14, 2020 :
    of course that issue will be there you have enabled it through settings and 100% it will be unstable
  12. Pravesh Popli
    Pravesh Popli , Jun 14, 2020 :
    You can put your phone on airplane mode while using vowifi. It will work fine.
  13. aakashsood
    Na I already tried that too. It still got disconnected.
  14. BeardyBiceps , via OnePlus 5T Midnight Black , Jun 14, 2020 :
    you have to clean install as you are on older android 9 beta . u cant just simply manually update, as others doing from stable android 9 OTA to Stable Android 10 OTA.
    you have to clean install via recovery mode.
    note all your data will be wiped.
    When you turn offband turn on via recovery mode that process you have to follow.
    UNG_mohamad_saad likes this.
  15. UNG_mohamad_saad
    Eclair Jun 14, 2020
    UNG_mohamad_saad , via OnePlus 5T , Jun 14, 2020 :
    so i need to enable advance reboot and from there go to recovery and update
  16. UNG_mohamad_saad likes this.
  17. UNG_mohamad_saad
    Eclair Jun 14, 2020
    yes i know how but i have never tried it [e]1f601[/e], only on Samsung devices
  18. UNG_mohamad_saad
    Eclair Jun 14, 2020
  19. BeardyBiceps , via OnePlus 5T Midnight Black , Jun 14, 2020 :
    better wipe all data and cache and all your device data too (images/music/anything)
    once cleared everything, then Install the package you downloaded from internal storage.
    that should fix your issue
