634
OxygenOS 10.0.0 for the OnePlus 5 and 5T
  1. nakulvk10
    Eclair Jun 14, 2020
  2. X3Mark
    Cupcake Jun 14, 2020
    X3Mark , via OnePlus 5T , Jun 14, 2020 :
    I only mentioned I was rooted to show no issues. I did get the update through the official updated as well. But because I'm rooted I use the updated app to get me the img file to flash in custom recovery.
    You don't have to be rooted to use the Oxygen Updater app. I originally started using it because you can get updates faster than the built in Updater. You probably won't get it till later because of how they roll out updates for different regions which is the issue I always have. The oxygen Updater app is not region specific so if an update is released it will pop up there usually within a couple of hours and is safe to use.
  3. Mathieu_
    Mathieu_ , Jun 14, 2020 :
    As for pretty much everything, I'd say you're 100x more likely to hear from unhappy people than from happy or neutral people.
    For me personally, there's no more issue after the latest update.
    Marleyfan61 and Shanley Damien like this.
  4. i_dare
    Donut Jun 14, 2020
    i_dare , via OnePlus 5 , Jun 14, 2020 :
    Glad you ain't having.
  5. Wilhelm69
    Gingerbread Jun 14, 2020
    Wilhelm69 , via OnePlus 5T , Jun 14, 2020 :
    Shanley Damien
    Is it working smoothly?..
    Any problems?
    Did you do a factory reset or just a normal upgrade?
    Bruh... it's same build but with hotfix for something but for what? We don't know bcs no changelogs
    Shanley Damien likes this.
  6. Deactivated User
    Jun 14, 2020
    Deactivated User , Jun 14, 2020 :
    For those unsure how smooth the update is, you only have to look at all the people whinging about not receiving the update yet. OnePlus slows/stops the rollout of major OS upgrades to more users when serious issues are uncovered. If you haven't got the update yet, consider yourself lucky. Just the fact not everybody has received the update yet, including in major markets, tells you all you need to know about the quality and stability of this new version.
  7. A1525542562586
    Eclair Jun 14, 2020
    A1525542562586 , via OnePlus 5T , Jun 14, 2020 :
    ohh is it. thank you soo much that was informative
  8. Navinmholkar
    Navinmholkar , via OnePlus 5 , Jun 14, 2020 :
    Hey which recovery you are using?
  9. saini.aman001
    Eclair Jun 14, 2020
    saini.aman001 , via OnePlus 3 , Jun 14, 2020 :
    No, its was a part of OnePlus commitment that they would deliver android 10 on a old phone like 5 & 5t.
    I believe they don't even tested this final update. It has lots of bugs and dont even expect that OnePlus will fix that issues .
  10. VibinRajan
    Donut Jun 14, 2020
  11. mpvigneshdat
  12. Rahul.na23
    A1509557061431 likes this.
  13. X3Mark
    OrangeFox recovery. It's a variation of TWRP. No issues so far. I mainly like the fact it has the option to remove or add Magisk with ease. so if you boot loop it can remove it. You don't need to worry about the Magisk uninstaller.
  14. Navinmholkar
    Does backup and restore works on this? Because other recovery has problem of restoring oos10.
  15. drvjshah
    drvjshah , via OnePlus 5 , Jun 14, 2020 :
    I Have updated to android 10 one week back.
    The battery life has reduced significantly after the update the screen on time comes max 3 and half hours.
    The phone hang up delay issue is back with this update which was solved with the last android 9 update.
    Apart from this two issues didn't find any other problems.
    Please fix the battery drain issue
    AviJaiswal likes this.
  16. paulomodesto
    Jelly Bean Jun 14, 2020
    paulomodesto , via OnePlus 5T , Jun 14, 2020 :
    It's a complain of almost everyone! Google forced Smartphone companies to adopt new Google system navigation gestures. OnePlus have accomplished the imposition but OnePlus doesn't allow users to control the sensitive of the swipe as Google does.
    Omar5T likes this.
  17. G_Akash_Siddhu_pkUN
    G_Akash_Siddhu_pkUN , via OnePlus 5T , Jun 14, 2020 :
    Install oxygen updater app and download the file from there. Place it in the root storage and flash
    Rahul.na23 likes this.
  18. VibinRajan
    Donut Jun 14, 2020
    VibinRajan , via OnePlus 5T , Jun 14, 2020 :
    Oh okay bro... thanks a lot.
  19. G_Akash_Siddhu_pkUN
    Did 90% of the people here know how to operate a smartphone. Just crying like babies i dont get the update . What is this there are solutions for these things like oxygen updater
  20. X3Mark
    I haven't tried yet. I've been using the OnePlus backup lol.
