634
OxygenOS 10.0.0 for the OnePlus 5 and 5T
  1. Navinmholkar
    Gingerbread Jun 14, 2020
    Navinmholkar , via OnePlus 5 , Jun 14, 2020 :
    No, not that backup. The system backup we make in twrp that one.
  2. X3Mark
    Cupcake Jun 14, 2020
    X3Mark , via OnePlus 5T , Jun 14, 2020 :
    yea I know you were talking about the TWRP backup. I haven't used that in sometime since it broke before. but I may try sometime.
  3. Navinmholkar
    Okay. Thanks for information. Post here if it works.
  4. Manjitenu
    Manjitenu , via OnePlus 5 , Jun 14, 2020 :
    I think, the way we updating 1lto OS10 is not correct. People are using Oxygen Updater for getting file thru reinstallation rather than puse file from OnePlus thru system update. Oxygen Updater is third party app. Might be OnePlus team is under the way modifying and removing bud. let's wait for some time and try thru system update
  5. haarish28
  6. AviJaiswal
    Eclair Jun 14, 2020
    AviJaiswal , via OnePlus 5T , Jun 14, 2020 :
    i have the same issue. they need to change the battery management algorithms or whatever.
    Omar5T likes this.
  7. omer3588
  8. dvdwouwe
    dvdwouwe , Jun 14, 2020 :
    Most of the complaints are reported. But most ppl that are happy with this update don't report this. So saying 90% is unhappy doesn't say nothing.
  9. G_Kamal_Hasan_nIkl
  10. Mehuljain12
    Mehuljain12 , via OnePlus 5T , Jun 14, 2020 :
    After this new update rolled out......some of the apps on the phone keeps on crashing ....it says that your phone is having connectivity issues but if you check your internet it works good. sometimes some of rhe apps stop working for some time...all you have to do is wait till it starts working again.
  11. DKesler
    DKesler , Jun 14, 2020 :
    I have had several issues after upgrading! I did exactly what says here.
    It shows graphic issues, lag and chrashes. Need some help!
    When i power on my phone it starts with some white lines and gets worse and worse.
    https://drive.google.com/file/d/1buoPCb3YFsSSK5dlwz7DkmStwX5M6_rM/view?usp=sharing
    Finally:
    https://drive.google.com/file/d/1p0w04nI0PpBRoax6QuZYI2XBmmmKLl12/view?usp=sharing
    I did all i saw here to solve: fastboot, hard reset/factory reset, downgrade to android 9 and till the same. Some help?
  12. Rags0310
    Rags0310 , Jun 14, 2020 :
    Hi All, I just upgraded my phone to Android 10, but now i couldnt see any images in the Gallery Folder,i can see only recently deleted folder with the images.
    The images are present in Google photos,but not in Gallery,tried restarting but did not work.
    And the phone crashes whenever an app is opened.
    Anyone else facing the issue?
    Plz help on this.
    rajeshpathikonda likes this.
  13. L1574545145975
  14. Marleyfan61
    Froyo Jun 14, 2020
    Marleyfan61 , Jun 14, 2020 :
    I've read the many complaints here. I think mostly that people who have something to complain about will post and those who are happy mostly remain silent. I used oxygen updater to upgrade from 9.0.11 and only wiped cache after installing. The only problem ive had is battery drain.
    I don't have call recording, but I didn't in pie either as I'm pretty sure it has to be allowed in your country. And I'm the one person who actually prefers the new gestures.
    I wish everyone had the same successful update that I've had. Hopefully all of your issues will be fixed soon.
  15. fajarlc86
    fajarlc86 , Jun 14, 2020 :
    thank you 1+, i've done update this phone.. but i just get problem, i can use feature "find my phone" with garmin connect.. is it garmin problem or 1+ side?
  16. A1513455633137
    Eclair Jun 14, 2020
  17. A1513455633137
    Eclair Jun 14, 2020
  18. rajeshpathikonda
    rajeshpathikonda , Jun 14, 2020 :
    My ring tone and vibration is turned off I think. I am unable to check it though. Every time I open Settings, it keeps shutting down as soon as i click "phone ringtone and vibration".
    J1570457089250 likes this.
  19. camohan
    Moderator Moderator Jun 14, 2020
    camohan , Jun 14, 2020 :
    If you have any issues with Moderation action, feel free to PM or report the action.
    By this way you are making yourself look bad.
  20. AviJaiswal
    Eclair Jun 14, 2020
    al ready did.
