631
OxygenOS 10.0.0 for the OnePlus 5 and 5T
  1. Peterxxx
    Ice Cream Sandwich Jun 17, 2020
    Peterxxx , Jun 17, 2020 :
    This is true black I think...
  2. G_Jaspreet_Singh_zNVl , via OnePlus 5T , Jun 17, 2020 :
    Hello, I have been facing certain issues post update.
    1) The call recordings are all distorted. The call quality is fine but the recording is all waste and distorted.
    2) Battery performance is really poor. with no background apps running, overnight the battery falls from 90% to 50%. if I check battery usage, it's nothing there.
    3) Device heating a lot when on call.
    please suggest what should I do. thanks.
  3. Ologu Alexandru Mihai , via OnePlus 5T Midnight Black , Jun 17, 2020 :
    I think the battery is almost dead mate, change the battery and stop letting your devices plugged in to charge overnight.
    F_Kent_Dialino_LnFy likes this.
  4. Swaraj_18
    Cupcake Jun 17, 2020
    Swaraj_18 , via OnePlus 5 , Jun 17, 2020 :
    Ever since I updated my OnePlus 5 I'm not able to use my mobile data, only WiFi works. What kind of issue is this and am I the only one with it ? Please resolve this issue soon OnePlus...
  5. G_Jaspreet_Singh_zNVl , via OnePlus 5T , Jun 17, 2020 :
    is there any way to check the battery health status, since it was working pretty fine on android 9.
    Rest I unplug the phone before I go to bed and clear the background apps. still without any usage and background activities the battery dies.
  6. Boggoman
    Donut Jun 17, 2020
  7. C1521044632584
    C1521044632584 , Jun 17, 2020 :
    I got the one plus 5t oxygen 10 update, there is only one tone in the phone ringtones, I can't make any other tone adjustments
  8. SIVAKARTHIK2407
    SIVAKARTHIK2407 , Jun 17, 2020 :
    After updating to new version of Android 10.0.0, I am not able to change the ringtone or any sound for notifications. Only beep sound is coming even after changing the sound in the settings.
    Any solution to this?
  9. Binnu
    Binnu , via OnePlus 5 , Jun 17, 2020 :
    In Last update in OnePlus 5, AllRingtone sounds are same ringtone message and ringtone All are same sound. please fix this Issue. #oneplus5
  10. superronny007
  11. G_Arvind_R_Fwhg
    G_Arvind_R_Fwhg , Jun 17, 2020 :
    hello,
    I updated my one plus five to Android ten.The ambient display is turned on but I don't see the display anymore. The battery drains quicker than before.
  12. ShuaibY
    ShuaibY , Jun 17, 2020 :
    i haven't got any android 10 update 🙁 What should i do ?
    Can anyone help me with ?
  13. ShuaibY
    My current version is Android 9
  14. mauier
    mauier , via OnePlus 5T , Jun 17, 2020 :
    FIX* GETTING BACK OLD NAVIGATION GESTURES
    1. Put the gestures navigation mode on
    2. Install SetEdit from Play store
    3. Find "op_gesture_button_side_enabled"
    4. Set the value to "0"
    5. Done
  15. fuwad563
    fuwad563 , Jun 17, 2020 :
    Facing issues with new update, Android 10. Chrome crashing, Gallery not working at all, file management not working, battery draining, google playstore crashing etc.
    edward_deruiter likes this.
  16. G_Akash_Siddhu_pkUN
    Gingerbread Jun 17, 2020
  17. Abhinav_Bhat
