628
OxygenOS 10.0.0 for the OnePlus 5 and 5T
  1. bsk.madhavi@gmai
    Froyo Jun 18, 2020
  2. kirank04
    Froyo Jun 18, 2020
  3. bsk.madhavi@gmai
    Froyo Jun 18, 2020
    bsk.madhavi@gmai , via OnePlus 5T , Jun 18, 2020 :
    Any solution to not get this auto rotation option while we tilt phone on Oneplus 5t Android 10
    Because of this right bottom corner auto rotation option phone frequently goes to landscape mode. Any settings we can disable. Help is appreciated
  4. udenjoe
    Cupcake Jun 18, 2020
    udenjoe , Jun 18, 2020 :
    Screenshot_20200618-092354.jpg Screenshot_20200618-092349.jpg Screenshot_20200618-092400.jpg This popup "Allow OnePlus Launcher to access your physical activity?" will not go away. I can't select Allow or Deny. I updated yesterday.
  5. F1592479486825
    Mobilnutzer and polblancafort like this.
  6. Simão99
    Froyo Jun 18, 2020
    Simão99 , via OnePlus 5T , Jun 18, 2020 :
    I updated yesterday to the new Android 10 and so far so good, I did a wipe cache and then a full battery discharge and im getting 5h30 + of screen on time! The same as with Android 9. One thing that's possible to improve are the new gesture, the back one, it should allow to make it largar to the screen, if you have a case it's harder to go back, and make it only possible on the bottom half of the screen. So in that way you can drag the hamburger menu withou a problem. In general im reay happy with the update, and its nice all-around!
    polblancafort likes this.
  7. Omar5T
    Honeycomb Jun 18, 2020
    Omar5T , via OnePlus 5T , Jun 18, 2020 :
    Could you check the accessibility in the settings?
    Shanley Damien likes this.
  8. Omar5T
  9. Omar5T
  10. Omar5T
    Appreciated [e]1f44d[/e]
  11. G_Ivan_Henrique_Tavares_
    G_Ivan_Henrique_Tavares_ , Jun 18, 2020 :
    Performance is terrible with android 10.
    It seem this migration was done only for the sake of updating with no polishment at all.
    Random crashes, stutter, sluggish performance. Picture in picture bugs, wifi disconnections, battery drains. Worst navigation gestures.
    I'm strongly considering going back to android 9.
    If this is the kind of update oneplus promisses, I'd prefer stick with 9 with security bugfixes... come on..
  12. PriyaJain1990
    Eclair Jun 18, 2020
    PriyaJain1990 , via OnePlus 5T , Jun 18, 2020 :
    headphone and wireless headset are having problems with this new update please fix it. Can't use my bullet wireless with its magnetic function properly. It won't start and stop it self now. Have to manually connect it every time.
  13. bsk.madhavi@gmai
    Froyo Jun 18, 2020
  14. balbal33
    xyz2552256 likes this.
  15. ninja123456
    Ice Cream Sandwich Jun 18, 2020
  16. gdpiraquivet
  17. dapakiguy
    dapakiguy , Jun 18, 2020 :
    bro i heard new updates delete all the pix and stuff..is it true?
  18. Beowulf1979
    Beowulf1979 , Jun 18, 2020 :
    hi,
    when I see all comments it's better to stay on 9? I'm not fan updating my phone only because Android number 😎
  19. Pritam_Dhokale
  20. srath75
    srath75 , via OnePlus 5 , Jun 18, 2020 :
    There is a trick to enable it.. Just google , you will find it.
