628
OxygenOS 10.0.0 for the OnePlus 5 and 5T
  1. jontalk
    Honeycomb Jun 26, 2020
    jontalk , Jun 26, 2020 :
    The 10.0.0 update has been removed from OTA servers due to the countless bugs reported. The Dev team is working on a new build that will need to be beta tested and with luck, released next month. Be grateful you haven't installed the previous one and remain patient. Good things come to those who wait.
    Shanley Damien likes this.
  2. Kailash_jain
    Donut Jun 26, 2020
    Kailash_jain , via OnePlus 5 , Jun 26, 2020 :
    After updating to Android 10 my phone call recording quality has deteriorated too badly. I don't know but some very different n robotic sort of voice is recorded instead of actual call voice!
    how to resolve??
  3. shivkarora
    Cupcake Jun 26, 2020
  4. Waveform Modifier
    Marshmallow Jun 26, 2020
    Waveform Modifier , Jun 26, 2020 :
    You should wait until OnePlus push the newer built. They pulled the current built.
    Shanley Damien and jontalk like this.
  5. Ologu Alexandru Mihai , via OnePlus 5T Midnight Black , Jun 26, 2020 :
    I noticed that on this update sometimes the audio tuner turns off when I connect earphones... like its playing on the speakerphone and you cant change anything, but after a restart is fine and it works as it should, I noticed cuz the sound was a bit muddier and I check the settings.
    Muditkhanna998 likes this.
  6. Natarajanvaidhy
    Gingerbread Jun 26, 2020
    Natarajanvaidhy , via OnePlus 5 , Jun 26, 2020 :
    Good for the explanation
  7. Muditkhanna998
    Gingerbread Jun 27, 2020
    Muditkhanna998 , via OnePlus 5 , Jun 27, 2020 :
    Try inserting the earphones slowly back in and you'll get it. Its.a bug
    Ologu Alexandru Mihai likes this.
  8. chemistril
    chemistril , Jun 27, 2020 :
    I don't have any of your problems guys! I have some bugs, but they are minor. I guess I'm lucky
  9. helloanish
    Cupcake Jun 27, 2020
    helloanish , Jun 27, 2020 :
    After this update my camera had some some issues like when I tried to capture any documents then the texts were getting blurred..be it snapchat or the camera...the texts are getting blurred
    abhirajput159 likes this.
  10. Muditkhanna998 likes this.
  11. Muditkhanna998
  12. F_Nikolay__Rubanovsky_Zh
    F_Nikolay__Rubanovsky_Zh , Jun 27, 2020 :
    I have an issue with telephoto lens after update. It gives a very distorted image (wavy) and blurry sides tried reinstalling camera - does not help. The main camera works fine.
    Also, if I move my phone , the image jiggles with inertia as if there is optical image stabilization that's broken. I know, sounds weird.
  13. chinnimadhav
    chinnimadhav , Jun 27, 2020 :
    Not only single issue
    but many
    audio issue
    battery backup issue
    phone heating
    charging slow sometimes
    signal drops
    call audio reverses sometimes like speaker and earpiece and vice versa
    heating while charging but before update no issue
    for a 10 min gaming only heats upto 44 degrees Celsius
    and also some minor issues which are rare
    mj_vagale likes this.
  14. ipankajmehta
    ipankajmehta , via OnePlus 5T , Jun 27, 2020 :
    Not able to connect my phobe to laptop. No option is popping up on screen like before and puttinh on charging 30% or below batteey is draining veey fast even on putting on charging
  15. Maitreya10
    Donut Jun 27, 2020
  16. ninja123456
    Ice Cream Sandwich Jun 27, 2020
    ninja123456 , via OnePlus 5 Midnight Black , Jun 27, 2020 :
    That issue is there for the most of us. When the device goes to sleep, the sensor refuses to recognise the fingerprint.
    Maitreya10 likes this.
  17. shafiq97
    Froyo Jun 27, 2020
  18. Waveform Modifier
    Marshmallow Jun 27, 2020
    Waveform Modifier , Jun 27, 2020 :
    App issues is the responsibility of the app dev
  19. chinnimadhav
    once re assign it again
  20. shafiq97
    Froyo Jun 27, 2020
    shafiq97 , via OnePlus 5T , Jun 27, 2020 :
    how can I get rid of the problem? actually I have updated the app of more than 5 times, still problem persists
