631
OxygenOS 10.0.0 for the OnePlus 5 and 5T
  1. Aakarshan.318
    Eclair May 27, 2020
  2. Q1573498478063
    Cupcake May 27, 2020
    Q1573498478063 , via OnePlus 5T , May 27, 2020 :
    umm cuz it lets me unlock a lot extra features on any android.. search on YouTube and you'll understand better
  3. F_Neeraj_Gujjar_tWRZ
  4. shaikmohammedari
    Eclair May 27, 2020
  5. joncharmed93
    Gingerbread May 27, 2020
    joncharmed93 , via OnePlus 5 , May 27, 2020 :
    This is done on purpose to fall in line with Google's latest Material Design.
    Aakarshan.318 likes this.
  6. Aakarshan.318
    Eclair May 27, 2020
    Aakarshan.318 , via OnePlus 5 , May 27, 2020 :
    If that's the case then the only issue I've noticed so far is Instagram Crashing.
    Thanks for answering!
  7. nbalakumar2005
    nbalakumar2005 , via OnePlus 5 , May 27, 2020 :
    Unfortunately I'm unable to enter recovery mode to wipe cache though I enter correct PIN :( tried multiple times but no luck
  8. MiguelP
    MiguelP , via OnePlus 5 , May 27, 2020 :
    Hey, I have a open beta 35 SO on my oneplus 5, it is necessary to install the stable version of the OS or I get the android 10 update even with the open beta?
    nithingowdac likes this.
  9. FusionBomber
    Honeycomb May 27, 2020
    FusionBomber , via OnePlus 5T , May 27, 2020 :
    Nope.
    Here's how Google's gap is justified, the nav bar and a toggle to minimize the keyboard is placed there. Whereas OOS's gap is gap. Empty.
    J1513597794949 likes this.
  10. ShadyAlGendy
    ShadyAlGendy , via OnePlus 5T , May 27, 2020 :
    If you are using magisk just make sure that oneplus dot fix is v5. 6
    joelshawdow likes this.
  11. AbhilashKotha
  12. Y1590600454523
    J1513597794949 and Mhtnr like this.
  13. nbalakumar2005
    finally I managed to wipe the cache 3 times but still no luck... mobile internet not working from Jio / Airtel network
  14. Toghrul_Tahirov
    Eclair May 27, 2020
    Toghrul_Tahirov , via OnePlus 5 , May 27, 2020 :
    That might be because of the app itself. If you are on the beta program for Instagram, then try uninstalling the app n erase its cached data, leave the beta program and after the beta tag of the app (right beside the name of the app in Playstore which should look like this "Instagram (Beta)") is gone, install it again. This did the magic for me and maybe is the case with u as well
    Harry d best likes this.
  15. Sid_Ck
    Ice Cream Sandwich May 27, 2020
    Sid_Ck , May 27, 2020 :
    OnePlus 7T is old not new
  16. ShadyAlGendy
    Thanks OnePlus for the updates
    Here are some issues that i found
    - call recording is not working properly very slow and laggy
    - still there is a gab under the keyboard
    - new gestures is a bit laggy comparing to the previous
    - wifi is not stable as previous
    Marek S. and joelshawdow like this.
  17. BeardyBiceps , via OnePlus 5T Midnight Black , May 27, 2020 :
    its incremental , you will get it soon.
    if can't wait, use Oxygen Updater.
  18. gutsygibbon
    gutsygibbon , May 27, 2020 :
    Anyone know how to upgrade from OP5T_O2_BETA_33 to the new stable 10.0? I tried downloading the stable 10.0 file and then doing local upgrade but it says the version is lower than currently installed and needs downgrade.
  19. Gersommelk
    Froyo May 27, 2020
    F1517582183217 likes this.
