573
OxygenOS 10.0.0 for the OnePlus 5 and 5T
  1. V1552405618713
    Cupcake Jul 14, 2020
    V1552405618713 , via OnePlus 5 , Jul 14, 2020 :
    OnePlus team,
    This behaviour is not a professional type
    I am using op5 and I was using it with Full confidence
    Recommended to my friends also
    But, this latest so called stable update is full of bugs and you people also known it
    Still there is no update to fix all this
    Is this a low grade technique? So that customer gets encouraged to change the device ?
    I think Battery, camera,alert slider and some other problems are bothering almost every op 5 user
    So what you want your customers to do
    Trust the brand?
    or just switch from one device to another???
  2. X1594737558034
    X1594737558034 , Jul 14, 2020 :
    I got the update a few days ago.
    I was really exited to see Android 10 on my phone.
    But there are a few issues I found.
    • I think there is something off with the storage drivers or something else with storage.
      App that use storage (podcast, music, file manager, ...) don't work, crash or tale a long time to load.
      Example: Play Music (from google) does not display album art and can not play songs.
      OnePlus File Manager Shows that I have no file, when selecting "Internal storage" it does not show me any folders, after a long time waiting it will list the folders but can not go back up the file hierarchy when I go into a folder.
      I can not connect my phone to my pc, phone charges but can not change the USB Preferences to "File transfer", option is grayed out. It does not detect that it can connect.
    • Taking screenshots give me a notification "Saving screenshot... Screenshot is being saved." but this never goes away, have to reboot to remove it. (screenshot is saved correctly, sometimes).
    • Share sheet takes a long time to open when clicking the share button.
    Have not found any other issues just yet. I think all these issues are related as they all use the filesystem for the bulk of the actions. Also tried some other file system app but some work, some don't. (my gallery app, "Simple Gallery - ..." by "Simple Mobile Tools" does not seem to have any issues. But sharing an image via Whatsapp crashes the app.)
    I think this is also related to the Instagram issue I have seen on the forums.
    Hope this is helpful in fixing some of the problems. If there are better ways to report issues let me know.
  3. markini
    Nougat Jul 14, 2020
    markini , Jul 14, 2020 :
    https://forums.oneplus.com/feedback?status=&node_id=&type=&phone_model=&phone_model_rom=
    X1594737558034 likes this.
  4. wileyc
    Jelly Bean Jul 14, 2020
    wileyc , via OnePlus 5 , Jul 14, 2020 :
    They have stopped the update due to number of problems. They are working on 10.0.1 and it should be out soon. Honestly you didn't want to upgrade to 10.0.0 as too many problems.
    shubhamg21 likes this.
  5. G_G_Rock_cxgs
  6. Rohan_S_P
    Honeycomb Jul 14, 2020
  7. Harry Shank
    Gingerbread Jul 14, 2020
  8. K1518814483499
    Atomic likes this.
  9. G_Ronen_Tveria_JMyj
  10. mkv13
    Donut Jul 14, 2020
    mkv13 , Jul 14, 2020 :
    @ Oneplus Staff : Helloooo?!It's mid july and we don t have a stable version and we won't buy oneplus nord.
    SHAME! SHAME! SHAME!
    Is my last OP phone. Bbye!
    bditno likes this.
  11. Waveform Modifier
    Marshmallow Jul 14, 2020
    Waveform Modifier , Jul 14, 2020 :
    Good news, no OnePlus staff here.
    OK. Sure.
    jontalk likes this.
  12. jontalk
    jontalk , Jul 14, 2020 :
    Use logic. This release forum is one of if not the LONGEST of any due to thousands or problems with 10.0.0. So ask yourself, "Why would I want to install it?" OnePlus is working on a new build though we have NO idea when it will begin beta testing. Regardless, WAIT until they release a STABLE version since this one is anything but :)
  13. niekko
    Eclair Jul 14, 2020
  14. panku_s
  15. ninja123456
    Ice Cream Sandwich Jul 14, 2020
    panku_s likes this.
  16. Sid_Ck
    Sid_Ck , Jul 14, 2020 :
    There is no WE you may say I
    Waveform Modifier likes this.
  17. mkv13
    Donut Jul 14, 2020
    ok, you have stable version and you ll buy nord. Anything else? something good 2 share? / ironic
  18. frank.bevers
    jontalk likes this.
  19. paulomodesto
    paulomodesto , via OnePlus 5T , Jul 14, 2020 :
    Why we cannot uninstall or simple deactivate de 2 file explorer on OxygenOS 10?
    I don't use non of them, I use for years one simple File Explorer downloaded from Play Store, so now I ended have 3 file explorer, and the two I don't use that come with OxygenOS 10 I cannot uninstall or even disable.
    OxygenOS is known to be near to stock Android and have few or no bloatware, but now we ended have 2 apps that do almost the same thing.
    P_Sai_Gopal likes this.
  20. paulomodesto
    The delay between Stable releases is 2 months in the first two years of life, ended that period you will have two months of Google security patch updates until you reach the third year of life, time that the device support end.
