634
OxygenOS 10.0.0 for the OnePlus 5 and 5T
  1. paulomodesto
    Jelly Bean Jul 15, 2020
    paulomodesto , via OnePlus 5T , Jul 15, 2020 :
    The solution is not delete cache, is full reset, delete everything, start all over from zero!!!
    Ajinx_Kale likes this.
  2. mr.smolda
    Froyo Jul 15, 2020
    mr.smolda , Jul 15, 2020 :
    Wiping the whole phone shouldn't be the main solution on stable version. But merely an alternative.
  3. paulomodesto
    Every time we change from an old version of Android full reset is very important.
    The behaviors you are having is proof of that.
    Apps crashing, bad Battery backup, and other behaviors is what most people would get if install a completely new OS version over the old one.
  4. mr.smolda
    Froyo Jul 15, 2020
    Phones from other brands work alright even without full resets after updates.
    I understand it always helps but I can't imagine a "normal" user reseting their phone with 3 years of data. It's just a struggle that shouldn't be necessary.
    But thank you for your advice. I just wanted to avoid such measures.
    mukundakdas likes this.
  5. bogdan.soare9
    Froyo Jul 15, 2020
    bogdan.soare9 , Jul 15, 2020 :
    Actually it did. I got my first A10 update about 3-4 weeks ago but I ignored it seeing all the bugs reported here. Now, a few days ago I got another A10 update notification and actually updated this time. Everything seems fine and I haven't even done a factory reset. Other than that, yeah, I'm waiting for EIS to be fixed...
  6. paulomodesto
    It's an Android thing, it happens to all brands.
    Some may be lucky not needing to reset but others, special those that have lots of apps it's perfect understandable problems could occurs.
    And in this case it's a device that have 3 Major updates, that means if you started with Android 7 and came through Android 8 and Android 9 without wiping with no problems, there is one big probability to happen with Android 10.
    Your problem only will be fixed with a full wipe, sorry to say that!
    mukundakdas and mr.smolda like this.
  7. ALy Enache
    Cupcake Jul 15, 2020
    ALy Enache , Jul 15, 2020 :
    Nu am inteles ce ai vrut sa zici 🙂
  8. ALy Enache
  9. ALy Enache
  10. Beowulf1979
    Beowulf1979 , Jul 15, 2020 :
    I've update to the last version ( i haven't done an update to 10 before this last one) and everything it's seems just fine. All previous app are there, I just don't like the new animations. 😬
    Shanley Damien likes this.
  11. Iv_arrais
  12. HapaxOromenon
  13. O1531788623010
  14. P1594827512755
    P1594827512755 , Jul 15, 2020 :
    sir, I am facing a issue in my OnePlus 5 mobile my ringtone sound was not ringing loudly while incoming call Soo please consider the issue n solving sir
  15. HaroonKhalifa
    Eclair Jul 15, 2020
    HaroonKhalifa , Jul 15, 2020 :
    Its been 1.5 months since updating, now apps like chrome, snapchat, playstore are lagging sometimes.
    Tried cleaning the cache but nothing helped.
  16. TanmayPimple
    TanmayPimple , via OnePlus 5T , Jul 15, 2020 :
    Open your phone app
    Got to call history section
    There are 3 vertical dots on the top right, tap on them
    Select settings
    Select sounds and vibration
    Disable "Riase to lower ringtone" option
    Disable "ascending ringtone volume" opinion
    Should work
    Beowulf1979 likes this.
  17. Omar5T
    Honeycomb Jul 15, 2020
    Omar5T , via OnePlus 5T , Jul 15, 2020 :
    Dude i think they lied to you
