608
OxygenOS 10.0.0 for the OnePlus 5 and 5T
  1. Firozkhans120
    Cupcake Aug 4, 2020
    Firozkhans120 , via OnePlus 5T , Aug 4, 2020 :
    After software update camera and call record are note working properly it's been morethan 2 months still waiting for bug fix. Everybody already pointed out this issue. Then why are you not taking any actions
  2. Rahul003@
    Cupcake Aug 4, 2020
    Rahul003@ , Aug 4, 2020 :
    Oxygen Updater showing an update of 1.8gb with same android 10 build number. Guys don't update it. it has a huge bug related with fingerprint sensor. after the update my fingerprint sensor is not properly working. only 1/5 time it's working even i did reset my fingers print but no luck at all.
  3. InkSlinger666
    Froyo Aug 4, 2020
    InkSlinger666 , Aug 4, 2020 :
    Mine still working as expected.
  4. Y1596518429261
    Cupcake Aug 4, 2020
    Y1596518429261 , Aug 4, 2020 :
    thanks for updating previously after entering pin no phone used to turn on automatically now we have to click on enter ✓ rest is fine
  5. KieYongH
    Eclair Aug 4, 2020
    KieYongH , Aug 4, 2020 :
    I am on stable 9.0.11,but I didn't receive Android 10 update.
  6. bussi1805
    Froyo Aug 4, 2020
    bussi1805 , via OnePlus 5T , Aug 4, 2020 :
    Well, August security patch is out. We're still on April. What will we get when the next update will be released? May? Or even June?
    Even Samsung does this better by now and they were once the archnemesis of updates.
    giacar96 and mukundakdas like this.
  7. Udaya_Chendur
    Honeycomb Aug 4, 2020
  8. KieYongH
    Eclair Aug 4, 2020
  9. Udaya_Chendur
  10. KieYongH
    Eclair Aug 4, 2020
  11. Udaya_Chendur
  12. KieYongH
    Eclair Aug 4, 2020
    kind of you[e]1f601[/e]
    udayachendur likes this.
  13. Ismet kjerimi
    Froyo Aug 4, 2020
    Ismet kjerimi , via OnePlus 5 , Aug 4, 2020 :
    Stay at 9.0.11 do not updated more OnePlus 5,I downgrade from android 10.0.0 is so buggy and laggy, They want you to buy new oneplus 5, is marketing strategy
  14. KieYongH
    Eclair Aug 4, 2020
    did you try clear data and cache after update?
  15. O1596524693795
    Cupcake Aug 4, 2020
    O1596524693795 , Aug 4, 2020 :
    Don't say things like that please.
    Do fresh install no update, and it work like a charm.
    For All please, if you upgrade to a major update, make a fresh install, or update your phone then reset everything + clear cache.
    This is the only way to get the phone work well.
    And this tips is for all other software like windows mac or android os, without fresh install it will be unstable because of remainder of the older version.
    Have a great day.
    ArmelHERVE likes this.
  16. surya1991s
    Cupcake Aug 4, 2020
    surya1991s , via OnePlus 5 , Aug 4, 2020 :
    How to clear cache and install it? Link please
  17. O1596524693795
    Cupcake Aug 4, 2020
    To install juste upgrade it from oneplus update manager on the phoen, you have the possibility to use adb but i don't recommand it for you.
    For reset , it's on settings, use research tool on settings.
    For cache it's on receovery mode > Power + Low volume push at same time during phone boot and clear cache + settings
    surya1991s likes this.
  18. G_BHAVESH_Shelar_HbVp , via OnePlus 5 , Aug 4, 2020 :
    I updated my OnePlus 5 after the update I'm having a huge battery drainage . playing pubg for around 1:45 min I get a huge battery drainage of 70 % or even more sometime . Without pubg or just browsing insta and fb etc it get drain about 50 to 60% in just 3 hour and I'm not even on my full brightness.it charge around 84% normally but above 84% it takes 1 hour .plz I need some help guys .I'm from Mumbai . OnePlus service center are closed .if there is any trick or so plz let me know
  19. joncharmed93
    Gingerbread Aug 4, 2020
    mukundakdas likes this.
  20. Tomhall
    Froyo Aug 4, 2020
