631
OxygenOS 10.0.0 for the OnePlus 5 and 5T
  1. ninja123456 , via OnePlus 5 Midnight Black , Sep 4, 2020 :
    In the post where many j mentioned that these new oneplus features are not hardware dependant and will be coming to oneplus 5/5t was the last offical message. There's no official post after that.
  2. rasulkhan7 , via OnePlus 5T Midnight Black , Sep 4, 2020 :
    All The Best Bro !
    kishor_d91 likes this.
  3. ninja123456 , via OnePlus 5 Midnight Black , Sep 4, 2020 :
    All the results from that search leads to XDA at the end. There is no authenticity in this post as he is not one of the oneplus employee
  4. rasulkhan7 , via OnePlus 5T Midnight Black , Sep 4, 2020 :
    I believe that they will not gonna come [e]270c[/e]️
  5. Itsme11
    Gingerbread Sep 4, 2020
    Itsme11 , via OnePlus 5 , Sep 4, 2020 :
    New software is still getting ready and if CTS. is passed..!!!..so in last 3 months no progress yet ..atleast software should get ready by now as CTS will take time ...
    rasulkhan7 likes this.
  6. paulomodesto
    Jelly Bean Sep 4, 2020
    paulomodesto , via OnePlus 5T , Sep 4, 2020 :
    https://forums.oneplus.com/threads/...eatures-heading-to-oneplus-5-5t-6-6t.1037976/
    "DC dimming
    This is an alternative method to adjust the screen brightness, by changing the circuit power of the screen. When enabled, it will reduce screen flickers at low brightness, but may lead to abnormal colors being displayed in some cases.
    We will introduce this feature in Open Beta builds for the OnePlus 6 and 6T and then evaluate for the OnePlus 5 and 5T."
    "RAM Boost
    Increase RAM utilization according to your usage. By learning how you use your phone, RAM Boost can predict apps you want to launch and data you want to load, thus taking full advantage of the available RAM to speed up your phone's performance.
    Currently, OnePlus 6 and 6T have the Smart Boost function and will upgrade to RAM Boost in future updates. The OnePlus 5 and 5T will also support this feature."
  7. MKT_IRFAN3735
    MKT_IRFAN3735 , via OnePlus 5 , Sep 4, 2020 :
    Thanks for the information
  8. paulomodesto
  9. NirajShakya
    Froyo Sep 4, 2020
  10. Harry Shank
  11. Harry Shank
  12. N1545231225658
    Froyo Sep 4, 2020
    N1545231225658 , Sep 4, 2020 :
    I don't know if this helps for people having battery drain issues but I noticed something lately. I started having severe battery drain going from 6-7h of screen on time to about 3h and seemingly no app was draining the battery. So I dug around a bit and I think some google play service was constantly using the location (gps) in the background. I turned location off to test it and I'm currently getting roughly an hour of screen time per 10% battery drain. Seems like an obvious bug.
  13. jontalk
    Ice Cream Sandwich Sep 4, 2020
    jontalk , Sep 4, 2020 :
    Yes..I posted in the 5T support forum after receiving an email stating a new build will be forthcoming soon. If you check you'll see the paste from the email. Unlike most in this discussion, be patient..it's GOING to come once they're satisfied it's bug free. They're obviously having trouble with Android 10 and if you check other device updates you'll see the 5/5T isn't the only one suffering problems
  14. Akashdeep081095
    Eclair Sep 4, 2020
  15. ArnabTalukder
  16. Harry Shank
    Harry Shank , via OnePlus 5 , Sep 4, 2020 :
    Kindly feel free to scroll up and read few posts you'll get an answer.
    Ovidiu_Ovidiu and cristi_lazar like this.
