634
OxygenOS 10.0.0 for the OnePlus 5 and 5T
  1. Bodygard
    Gingerbread Sep 15, 2020
    Bodygard , Sep 15, 2020 :
    People should forget Android 11. Not gonna happen. We could consider ourselves very happy if they release a final Android 10 with at least most of the important bugs corrected.
    Auzzya and RevidFfum like this.
  2. J W K
    Donut Sep 15, 2020
    J W K , Sep 15, 2020 :
    I have the same problem and it is getting worse. I have no idea why it is getting worse getting stuck for up to 10 seconds and longer now. The phone has become totally unusable and I had to switch to my Redmi Note Pro 8 which makes me happy again. I can't believe that this is deteriorating hardware but software which is extremely faulty. OP is going to loose a lot of customers. I was very happy with my first Oneplus and for 2 years with the 5T until now. Too bad.
    aero2 likes this.
  3. bsk.madhavi@gmai
  4. TheDarkDan
    Gingerbread Sep 16, 2020
    TheDarkDan , via OnePlus 5T , Sep 16, 2020 :
    Not if but when. They have to give us a stable Android 10. I think they're gonna give it to us the day the 5t was released since it's the last software update, but we'll see.
    explorohan and nguyenphong108 like this.
  5. Vaibhavmalik
    Eclair Sep 16, 2020
    nguyenphong108 likes this.
  6. Harry Shank
    Harry Shank , via OnePlus 5 , Sep 16, 2020 :
    You can use it only as any other earphone. You won't be able to customise it. OnePlus buds support app is not compatible in 5/5t.
    Moreover you can't use the inbuilt audio tuner for bluetooth headsets
    Vaibhavmalik and nguyenphong108 like this.
  7. D1511587380662
    Froyo Sep 16, 2020
  8. narendraawana3
    Cupcake Sep 16, 2020
  9. tikledarshan
    Auzzya likes this.
  10. paulomodesto
    Jelly Bean Sep 16, 2020
    explorohan, rimaqu, Atomic and 13 others like this.
  11. paulomodesto
    Atomic, marfz and mansch like this.
  12. Ajinx_Kale
  13. RevidFfum
    RevidFfum , via OnePlus 7T Glacier Blue , Sep 16, 2020 :
    [e]1f602[/e][e]1f602[/e][e]1f601[/e]
  14. RevidFfum
    RevidFfum , via OnePlus 5T Midnight Black , Sep 16, 2020 :
    I liked the update. I have an intl unlocked version, although I did not update right away, have not experienced issues.
    I don't use G. pay, so don't know if there are NFC issues others have reported. I do get notification of some apps draining the battery, I just force stop them, firgured it was normal, and it doesn't happened enough to be nuisance, normally after I just used said app.
    Unfortunately, OnePlus most likely sees the 5s, close to end of life, no longer a priority, which is negative mark on them, as support for their phones is one of their major selling point for me.
  15. Auzzya
  16. paulomodesto
  17. markstein
    markstein , Sep 16, 2020 :
    Promises to keep: Stable Android 10 in mid-July & Security updates every two months
    Promises kept: No stable Android 10 in September & No security update since April
    Auzzya, D1527579373524, Zluk and 3 others like this.
  18. Deactivated User
    Sep 16, 2020
    Atomic and nguyenphong108 like this.
