Shivang Joshi
To everyone who is facing the issue of Instagram crashing again and again:
Hi,
I've been facing some Instagram crashes today when I try to add a post from the feed to the story. However, on further investigation, I found that it might just be due to the Instagram update which came in a few hours ago.
As of now, I have tested it on the OnePlus 6T - running on Android 10 Stable. And I was facing that issue. However, when I tried to perform the same action through a secondary device (running on Android 9.0) - on which I hadn't installed that new Instagram update - I was able to complete the action successfully.
Later on, I installed the update to see if the app crashes or not. And it did. The Instagram app crashed every time I tried to add a post from the feed to the story - on that secondary device. So, it seems like the issue is with the Instagram app right now and we should be waiting for the update from their end.
I'll update this post when they release a new update for Instagram and will confirm if the issue is solved.
Note: I'm currently on the beta version of Instagram.
to add, if you are beta tester, leaving the beta program will surely help! worked for me!
