574
OxygenOS 10.0.0 for the OnePlus 5 and 5T
  1. F_Divyesh_Kumar_AZXU
    Honeycomb May 28, 2020
  2. Azeeb_IND
    Gingerbread May 28, 2020
    Azeeb_IND , May 28, 2020 :
    currentli im in beta 2 of android 10, should we get update through OTA or we can manually install the stable version?
  3. G1518628182367
    Froyo May 28, 2020
    G1518628182367 , via OnePlus 5T , May 28, 2020 :
    the volume has been reduced a little bit
    and in landscape mode the typing is very difficult due to new gesture and while gaming back button switches to down and close button disappeared
    G_Emad_Mosa_YIKE likes this.
  4. VIJAYKN04
    Cupcake May 28, 2020
  5. taby8706
    Eclair May 28, 2020
  6. amitratan
    Eclair May 28, 2020
  7. SudebCena
    Donut May 28, 2020
    SudebCena , via OnePlus 5T , May 28, 2020 :
    5mins into the new update, the blank space under the keyboard is really bugging me! [e]1f613[/e][e]1f613[/e][e]1f613[/e]
    Will give a detailed report after a few days.
    Thank You for Android 10 [e]2764[/e]️
  8. vanbommel04
    vanbommel04 , via OnePlus 5 , May 28, 2020 :
    if its gonna cause problem I'll not share it. there's no issu in my Oneplus5. You can see the bottom bare in the picture. if you can't handle adb don't try this.
  9. rohanjain99
    Eclair May 28, 2020
    rohanjain99 , May 28, 2020 :
    Updated OnePlus 5 , no problem but no wifi calling option available,all working smooth ,camera also good, no space below kewboard, video recording good
  10. rohanjain99
    Eclair May 28, 2020
  11. ninja123456
    Ice Cream Sandwich May 28, 2020
  12. ashish244
    ashish244 , via OnePlus 5T , May 28, 2020 :
    Updated to oxygenOS 10 and found no problem. Infact it is really smooth. Navigation is changed which I will get used to it but I used to like the previous ones. Space below keyboard is there which isn't a big issue..I mean we will get used to it if that's permanent. Overall its good. Everything is working fine. [e]270c[/e]
  13. G-Par
    Donut May 28, 2020
    G-Par , via OnePlus 5 , May 28, 2020 :
    Hello, great job for the update. No problems so far and the battery is great.
    I just noticed in the lock screen, that the fingerprint icon is above the clock instead in the bottom middle of the screen. Is this normal?
    K500i likes this.
  14. Sidd_G
    rasulkhan7 likes this.
  15. sachin.deokar1983
    sachin.deokar1983 , via OnePlus 5T , May 28, 2020 :
    My 5T has problems with call recording after updating to OxygenOS 10. The recorded voice is distort, broken and unclear. It was working fine with the last OxygenOS 9.0.11.
  16. Malg220
    Malg220 , May 28, 2020 :
    It's normal don't worry
    G-Par likes this.
  17. G-Par
    Donut May 28, 2020
  18. sachin.deokar1983
  19. F1521649744471
    Donut May 28, 2020
    F1521649744471 , via OnePlus 5 , May 28, 2020 :
    Hi,
    Just got the OTA for OOS 10 for OP5, it has bugs few which I faced:
    1 if we force dark mode from developer option, it changes the icon style and accent colors.
    2. UI lags randomly.
    3. Battery drainage.
    please look into the issues.
    thanks.
  20. amitratan
    Eclair May 28, 2020
    amitratan , via OnePlus 5 , May 28, 2020 :
    gr8 then I shall try [e]1f44d[/e]🏻
