608
OxygenOS 10.0.0 for the OnePlus 5 and 5T
  1. Kannathasan Kesavamani
    Cupcake May 29, 2020
    Kannathasan Kesavamani , May 29, 2020 :
    1. I could see the pictures are in File manager but the same is not showing in Gallery.
    2. Play store keep on crashing
    3. mtorrent is also keep on crashing
  2. Sid_Ck
    Ice Cream Sandwich May 29, 2020
    Sid_Ck , May 29, 2020 :
    Wifi calling option is not present for Airtel sim
    I guess it's enabled for users who had it enabled earlier via logkit
  3. B_Lalit
    Donut May 29, 2020
  4. Bpb37
    Bpb37 , via OnePlus 5T , May 29, 2020 :
    thanks It worked for the play Store but what about the problem with gallery?
  5. Pepe0105
    Donut May 29, 2020
    Pepe0105 , via OnePlus 5T , May 29, 2020 :
    i am still using beta 33 android 9. if manually upgrade to beta 3, it said will wipe all my data. i don't want lose my data. Should i wait for the OTA (beta)? please inform..thanks
  6. ninja123456
  7. Aakash786
  8. ninja123456
    ninja123456 , via OnePlus 5 Midnight Black , May 29, 2020 :
    there will be no beta ota. stable ota has already arrived. which you will not receive. you need to download full android 10 rom and flash it from recovery. you will lose data in this process.
    one reason why you should wipe the data is because, if you don't the os will not be smooth.
  9. R1530948757381
    Gingerbread May 29, 2020
    R1530948757381 , May 29, 2020 :
    in new update, any one is able to make calls from secondary sim where Idea network is using and primary network is Jio for internet in India.
  10. arunsesh81
    arunsesh81 , May 29, 2020 :
    Try Clear cache and clear storage data from Download Manager under Apps & Notifications, it should work..
  11. arunsesh81
    try uninstall & install android system webview from playstore
  12. Pepe0105
    Donut May 29, 2020
    ninja123456
    one reason why you should wipe the data is because, if you don't the os will not be smooth.​
    thanks for your answer. oxygenos 10.0.0 its means only for stable. and the data wiped is included our photos, apps, notes.. everything? 🙈 or just wipe the older OS system?
    i can't believe that..
    please inform me..thanks. [e]1f64f[/e]🏻
  13. MrLalsa
    Eclair May 29, 2020
    MrLalsa , via OnePlus 5T , May 29, 2020 :
    if you not bring back 3 pills navigation gesture in oneplus 5t you should not claim as a big company... it's little things. hope you understand.
  14. ninja123456
    everything goes
  15. binoganera
    Eclair May 29, 2020
    binoganera , May 29, 2020 :
    Update: Everything is working fine on my end. Getting an average of 4-5 hours SOT per charge. No issues encountered.
  16. MrLalsa
    Eclair May 29, 2020
    if oneplus 6 and 6t have bottom gesture option available then why you removed it from oneplus 5 and 5t? are you crazy?
    please please please oneplus team bring it back.
    Nigsupreme likes this.
  17. skipperto
  18. tttimmer
    Donut May 29, 2020
    tttimmer , via OnePlus 5 , May 29, 2020 :
    After restarting my OP5 once again, chrome is working as expected...
  19. Karthick RK
    Eclair May 29, 2020
  20. P1518329103663
