608
OxygenOS 10.0.0 for the OnePlus 5 and 5T
  1. nash6688
    Gingerbread May 29, 2020
    nash6688 , via OnePlus 5 , May 29, 2020 :
    Hello All - I just updated my OP5 to android10 and I'm getting annoying notification sounds for all the apps while im on phone call , can someone please help to disable the notification sound while one is on phone call.I checked for solutions on the internet but came to know this is a feature of Android10 lol, it is very annoying
    Thanks
  2. deven2208
    Cupcake May 29, 2020
  3. raj.vardhan21
  4. ipconfig1
    ipconfig1 , May 29, 2020 :
    These settings don't do the effect I am looking for.
    If the alert slider is in silent mode: There is no vibration for incoming calls and there is no setting to change that. Only 1 setting option to activate vibration for calls in silent mode would be the solution for my whole problem.
    If the alert slider is in vibration mode: Messages and notifactions DO vibrate, even if you set them to not vibrate in the app. This is because OnePlus settings only allows 3 intensities for notification vibration, but not a TURN OFF VIBRATION. This setting would be the solution to my problem as well.
    If the alert slider is in ring mode: Calls can not be made silent, so every call will produce a ringtone, which is not what I want.
    I just want everything to be silent and non-vibrating, except for calls, they should be silent but vibrating! This works on every other phone I've ever owned and it worked on the OnePlus 5 when I first got it as well!
    This is so so disappointing :( I will need to go away from OnePlus if they don't fix it, although I so don't want to. But this is inacceptable
    //: Edit: There may be an option I've just discovered, which is go to every single app's setting and change the notification importance to "less important", it says that it won't make a sound or vibration then.
    //: Edit2: Doesn't work either, the settings set itself to "important" again and again. So still every notification is vibrating
  5. HadiFab
    Eclair May 29, 2020
  6. Arsath1994
    Froyo May 29, 2020
    Arsath1994 , May 29, 2020 :
    please add old navigation control (swiping up for back), using left and right side of the screen is bit uneasy. I guess some others also feel the same.
  7. Ma_Fi
    Eclair May 29, 2020
    Ma_Fi , via OnePlus 5 , May 29, 2020 :
    [e]1f44e[/e]🤦
  8. mahtab1900
  9. D1567000681328
  10. IamAbhijit
  11. G_Neel_Roy_vDdH
  12. Sanjeev kumar 923
    Eclair May 29, 2020
  13. Tejas Tharu
  14. Pawan004
    Eclair May 29, 2020
    Pawan004 , via OnePlus 5T , May 29, 2020 :
    I have noticed a noticable latency in sound in my OnePlus 5T when it's connected to OnePlus bullet wireless Z while playing games like Pubg if this can be fixed I have no other issues
  15. chinnimadhav
    chinnimadhav , May 29, 2020 :
    i cannot find that option in op5t
  16. chinnimadhav
  17. chinnimadhav
  18. NShankaraN
    Froyo May 29, 2020
    NShankaraN , via OnePlus 5 , May 29, 2020 :
    Your Edit 1 worked for me. Now I'm getting the notification sound and vibration to only those apps whose notifications is categorised as important
