608
OxygenOS 10.0.0 for the OnePlus 5 and 5T
  1. berktjah
    Gingerbread May 29, 2020
  2. paulomodesto
    Ice Cream Sandwich May 29, 2020
    paulomodesto , via OnePlus 5T , May 29, 2020 :
    Best way to have less bugs and less stress with this update is:
    Full wipe.
    Fresh install full rom.
    Don't restore backups.
    And even with that, people will find some annoying bugs with this beta "sorry I was going to say stable" but the fact is that this is still a beta released as stable, there's plenty of things to be fixed.
    Irongaze85 likes this.
  3. ajayojhaca
    Cupcake May 29, 2020
    ajayojhaca , via OnePlus 5 , May 29, 2020 :
    you can change from customization
  4. hameshrshah
  5. Arnima27
  6. hameshrshah
    hameshrshah , May 29, 2020 :
    check for updates manually in ur phone thru settings.
  7. paulomodesto
    If you read the answers in that topic you will find a answer to your question.
    And you don't have to read much to see bad behavior of doing that.
    But yes, it seems there will be some downsizing behaviors, only you will know if it will affect your experience or not.
  8. Arnima27
    Arnima27 , May 29, 2020 :
    It tells me 'your system is up to date'.
  9. hameshrshah
    what is the version of ur os? is it showing 10.0.0
  10. Carlton Castelino
    Carlton Castelino , May 29, 2020 :
    I switched off and on the phone and the issue was fixed.
  11. Arnima27
    No it's 9
  12. hameshrshah
  13. Wolf1596
    Wolf1596 , May 29, 2020 :
    Working just fine..I guess.
  14. Arnima27
    hoping for that , btw thanks :)
    hameshrshah likes this.
  15. Wolf1596
    I have done that, but I'd like to add, that the vibration happens when I wake the screen with double tap.
  16. berktjah
    berktjah , via OnePlus 5T , May 29, 2020 :
    yeah I don't think you can turn off gesture vibrations.
  17. Wolf1596
    berktjah
    yeah I don't think you can turn off gesture vibrations.​
    Well.
    Thanks.
    It has happened after upgrading to Android 10.
  18. paulomodesto
    You guess?
    How about the shaking when recording videos?
    One of the features our device have when was released was EIS, and now we are running a stable version of OxygenOS and we don't have it.
    How about the heat in back of phone when charging, or when using some apps?
    You cannot use apps of reality augmented that is based on ARCore from Google because OnePlus 5/5T some how have lost compatibility with that app.
    It works, but not as flawless as OxygenOS 9.
  19. rohanjain99
    Eclair May 29, 2020
    hjs2396 likes this.
