252
OxygenOS 10.0.1 for the OnePlus 5 and 5T
  1. L1519865420469 likes this.
  2. Shadink
    Gingerbread Dec 19, 2020
    Shadink , Dec 19, 2020 :
    yea, the "clear cache" thing is kept being thrown randomly. Anyway, it's free i agree but if that was necessary, then developers would allow clearing cache right after updating the OS.
    And as i said, yes, clear cache can be picked as a solution if the device is not functioning.
  3. rasulkhan7
  4. Rhynero
    Cupcake Dec 19, 2020
    Rhynero , Dec 19, 2020 :
    Does anyone have an issue where after installing the update, the phone goes to the setup screen where you can select your language and then it goes to the 'just a sec' screen and gets stuck there?
    I really need to find a fix
  5. zer0se7en
    Ice Cream Sandwich Dec 20, 2020
    zer0se7en , via OnePlus 7T , Dec 20, 2020 :
    Nope. Running smooth on my side. I gave the phone to my dad.
  6. Gracjallini likes this.
  7. DogeAlpha
    Honeycomb Dec 20, 2020
    DogeAlpha , Dec 20, 2020 :
    Wonder if they'll provide another update. They didn't explicitly say this is the last one like they did with the OnePlus 3/T
  8. Q1528835969784
    Donut Dec 20, 2020
    Gracjallini and Shadink like this.
  9. Natarajanvaidhy
    Gingerbread Dec 20, 2020
    Natarajanvaidhy , via OnePlus 5 , Dec 20, 2020 :
    Replacing the battery is a known option. However, study the following:
    May be the usage of the applications are extensive during the referred period and the system computes the time for complete drain, on your known pattern of use. Rest the phone for 30 minutes and chech the drainage pattern, before taking a call.
    jontalk likes this.
  10. Natarajanvaidhy
    This OnePlus 5 is over 3.5 year old. The time now is 17 Hours and the full drain on known usage pattern is tomorrow 13.15 Hours.
    G_Peter_Soliman_mYqj likes this.
  11. Ortizalx
    Froyo Dec 20, 2020
    jontalk likes this.
  12. amitratan
    Eclair Dec 20, 2020
    amitratan , via OnePlus 5 , Dec 20, 2020 :
    After updating this version phone has began to act weird. 9 was a very stable version. @OnePlus If you are not planning to give another version that's fine but at least make android 10 stable version.
    Who all are facing this issue?
  13. W1608480075998
    Cupcake Dec 20, 2020
    W1608480075998 , Dec 20, 2020 :
    Can someone guide me through on what and how do I reset my OP5 to get better battery life? My current SOT is concerning as I don't have a heavy usage and I can't afford a new phone right now and repairs might not be possible right now. I've tried resetting and going back to A9 and updating via OTA update to A10 but the drain is horrible and it's difficult to make it last a day without charging. Seeing other fellow OP5 users get 5+hrs of SOT is really worrying me out about mine. No other bugs as such. Any help is appreciated
  14. Prabhasmaurya4
    Eclair Dec 20, 2020
  15. jontalk
    jontalk , Dec 20, 2020 :
    Looking at the apps you're using in the second image, the logical conclusion is the sheer number of third party apps you're using could be the problem. Try removing a bunch, testing for a couple of days and see if it improves.
  16. jontalk
    OP isn't going to read your posts. Instead use the Feedback section or bug report tool. Support has stated a 10.0.2 is in the works though they won't say when it will be released. I agree about A9 stability which is why I haven't installed A10. Add to that 10.0.1 has outdated security and GSM patches I'm going to wait and see if the next one is better. I get great battery life and have zero problems with 9.0.11. Android 10 features are few if any. Enough said
  17. Young_Blood
    KitKat Dec 20, 2020
    SmartUserS likes this.
  18. amitratan
    Eclair Dec 20, 2020
    Totally agree with you. I think I am gonna post in feedback sec. The battery is dying like anything. Every few hours I am recharging my mobile.
  19. jontalk
    Every few hours? Yikes. I have a feeling its either time to replace your battery or get a new phone. The other option is charging the phone, installing this battery health app, t.ly/cYUs and looking at the efficiency. With a 90% charge mine reads 79% which for a phone this age seems great!
