259
OxygenOS 10.0.1 for the OnePlus 5 and 5T
  1. jontalk
    Ice Cream Sandwich Dec 20, 2020
    jontalk , Dec 20, 2020 :
    I also suggest you try removing apps and checking. Most with battery drains haven't had problems with Android 9 but since you've tried, all things point to the apps or the battery itself.
  2. ninja123456 , via OnePlus 5 Midnight Black , Dec 20, 2020 :
    Replace battery
  3. _Aditya_Jain_
    Honeycomb Dec 20, 2020
    _Aditya_Jain_ , via OnePlus 5T , Dec 20, 2020 :
    If the battery is really bad and you wish to keep the phone for another year or so, I advise you to get the battery replaced.
    There might still be 50% discount on battery replacement for OnePlus 5/5T and you'll get it all for about ₹1000.
    If you want to save the service charge of ₹472 from the above amount, go on 17th of next month. They waive off that charge on that day.
    L1605246346984 likes this.
  4. DanManthe1PlusFan
    Cupcake Dec 20, 2020
    DanManthe1PlusFan , Dec 20, 2020 :
    I had an issue when I updated to 10.0.1 - my phone mic stopped working when I made or received calls. BTW, I use TMobile as a carrier for my OP5 and have never had this issue before. I did a clear cache on the recommendation of the OP customer support, but ultimately I had to do a factory reset to get it back to working. Weirdly, even after the reset it didn't resolve immediately. About an hour after I did the reset I got a call and when I answered my phone was working like normal again. Not sure exactly what happened during that hour, but if anyone else experiences troubles then I've got a datapoint that indicates it could be solved by a factory reset (remember to backup everything important first!)
    This is my first post, btw, so hi all!
    G_Peter_Soliman_mYqj and jontalk like this.
  5. G_sourabh_patil_jIEm
    Cupcake Dec 21, 2020
    G_Peter_Soliman_mYqj likes this.
  6. D.Sai Suhail Baba
    Jelly Bean Dec 21, 2020
    D.Sai Suhail Baba , Dec 21, 2020 :
    system
    • Fix the problem that the weather application crashes with a small probability
    • Update Android security patch to 2020.11
    Here's new software update released for Chinese Devices , Global devices will receive update soon.
    But Under system global Update may include some changes based on Global Users feedback.
    Deepak@1 and Shadink like this.
  7. Deepak@1
    Froyo Dec 21, 2020
  8. Young_Blood
    KitKat Dec 21, 2020
  9. Bodygard
    Gingerbread Dec 21, 2020
    Bodygard , Dec 21, 2020 :
    Phones who have low battery autonomy and you have tried everything, clean flash, delete apps, delete cache etc consider replacing your battery. Remember that if you use your phone a lot and charge it a lot of times, the battery lost efficiency and might be time to replace it. It's not expensive.
    About the update, no one knows. We're past the 3 year mark now and they don't have the obligation to give us any more updates. Although they delayed forever Android 10 with a lot of bugs and they still didn't put EIS working properly in this final release. If fact, it doesn't work at all, there's no stabilization and we had that in Android 9. The least they could do is try to correct that. Maybe we have another update with November security and some bug correcting in January or February.
  10. _Aditya_Jain_
    Honeycomb Dec 21, 2020
    _Aditya_Jain_ , via OnePlus 5T , Dec 21, 2020 :
    All I can see now are maybe one or at most two small updates to fix the bugs before they launch the OnePlus 9, i.e. around March-April 2020
  11. C1608620747600
    Cupcake Dec 22, 2020
    C1608620747600 , Dec 22, 2020 :
    I am unable to update my one plus 5 device to android OS 10.I am currently using android 7.1.1 version. I want to update it.
  12. Deepak@1
    Froyo Dec 22, 2020
    Deepak@1 , via OnePlus 5 , Dec 22, 2020 :
    Keep backup your data and use oxygen Updater from play store.
  13. Deepak@1
    Froyo Dec 22, 2020
  14. aero2
    Froyo Dec 22, 2020
    aero2 , via OnePlus 5 , Dec 22, 2020 :
    When someone finally write on their twitter
  15. DogeAlpha
    Honeycomb Dec 22, 2020
    DogeAlpha , Dec 22, 2020 :
    Great. Security patch that's almost 2 months old.
    The phones will stop receiving updates anyway, why would I care about a patch that will stay outdated anyway. Let's just hope they will further optimise the os
  16. D.Sai Suhail Baba
    Jelly Bean Dec 22, 2020
    D.Sai Suhail Baba , Dec 22, 2020 :
    2020.11 is November security patch , not 2 months old security patch.
  17. D.Sai Suhail Baba
    I think it would be better if they had released Update with 2020.12 December security patch. As it's near for EOL.
  18. Bodygard
    Gingerbread Dec 22, 2020
    Bodygard , Dec 22, 2020 :
    The question is let's see when will they release the update for OxygenOS in the West market region. Maybe January-February with a November security patch...
    But then again, they don't have the obligation to do it because it's EOL right now. Like i said before in many posts, the damage has been done. Oneplus failed to deliver and let 5/T users down. They cannot recover their image at least for me and many others. That's why i moved on and bought a smartphone from another brand.
  19. DogeAlpha
    It is November the 1st or maybe 5th. By the time they push this globally it will be January which means 2 months old patch.
    Not that a month or 2 would make any difference. An old patch is still an old patch
    marfz and D.Sai Suhail Baba like this.
