248
OxygenOS 10.0.1 for the OnePlus 5 and 5T
  1. Waveform Modifier
    Marshmallow Mar 28, 2021
    Waveform Modifier , Mar 28, 2021 :
    I never said it was right or not. I know it's BS. That's why I'm strongly considering not getting another OnePlus device again.
    SmartUserS, MOh.1, a4aravindg and 3 others like this.
  2. Waveform Modifier
    Truth is, it still doesn't change the fact that is had been declared EOL. Honestly, I believe they will definitely reap what they sow eventually.
  3. vinodh_dasari
    Froyo Mar 29, 2021
    vinodh_dasari , via OnePlus 5 , Mar 29, 2021 :
    Is there going to be another release with big fixes atleast.. I am facing call delay issues while receiving and while ending the call as well ...
    Or is it better go back to 9 version njoy the things...
  4. Waveform Modifier
    Marshmallow Mar 29, 2021
    Waveform Modifier , Mar 29, 2021 :
    I would say you have the odds of 9000000000000:1 chance.
    D.Sai Suhail Baba likes this.
  5. lneam
    Eclair Mar 29, 2021
    lneam , Mar 29, 2021 :
    before one week i decided to update to android 10.0.1 into my 5T.
    I made a hard reset to android 9.0.11 and then update to 10. After that a new hard reset. Then, i play for 2-3 hours to discover the new android features. At the end, when i was ready, a new hard reset and then i setup my 5T with google account and my personal apps and android settings (similar to android 7 8 9 for the last 3 years).
    i have found a few things i need to solve. For now i say only 2.
    - i can't found where it has gone the option from the settings
    recent app management - deep clean
    - notification
    with android 9, i had no issue. For example, when the battery reach 15%,
    - there was a sound
    - into the android bar, there was one icon
    - when i scroll down the upper top screen, there was one notification
    - BUT the most important, it was one small window inside the screen of the application i was running, for example the Sygic navigation, to inform me about the low battery.
    now with android 10, all the notifications has over 70% changed, the way to inform me. I have visit android 10 settings and i don't have found any issue. All the settings looks similar to android 9 and all the app settings are the same. So, why there is no 100% the same notification behavior for all the apps ?
  6. Gracjallini
    Donut Mar 29, 2021
    Gracjallini , Mar 29, 2021 :
    Mi 11 Ultra just launched, and it's soooooo much better im every way possible than 1+ while being cheaper 🤣
    4yrs of 1+ shite just finished, ordering one ASAP
  7. Danilo Oriani
    Cupcake Mar 30, 2021
  8. gauravmalik007
    Gingerbread Apr 1, 2021
  9. gauravmalik007
  10. LUKITO
    Froyo Apr 2, 2021
    LUKITO , via OnePlus 5T , Apr 2, 2021 :
    OnePlus 5T will be my first and last OnePlus product, though I was very satisfied with it and Android 7/8/9, if an A10 software update with solved all bugs won't be released. This is almost 1 year ago they've released the first A10 update, and now, after almost a year, nothing has been done to fix it. Shame on you OnePlus.
    Gracjallini, skybiz, MOh.1 and 6 others like this.
  11. Nil_s7
    Gingerbread Apr 2, 2021
    Nil_s7 , via OnePlus 5 , Apr 2, 2021 :
    Same here👍
    skybiz, D.Sai Suhail Baba and LUKITO like this.
  12. Nil_s7
    One thing I wants to share with OnePlus
    “It’s not how you start, but it’s how you finish.”
    — Michael Phelps
  13. Orbitty
    Cupcake Apr 3, 2021
  14. DumF0rGaming
    Eclair Apr 4, 2021
    DumF0rGaming , Apr 4, 2021 :
    Some people didn't believe in existance of optimistic promises support is offering us so I managed to try myself. Here's what I came up with, hopefully it's not private dialogue. Let's see where it goes this month
    dhames, arpit_19., SmartUserS and 7 others like this.
  15. DumF0rGaming
    Eclair Apr 4, 2021
    Maybe someone else should just ask about the update for 5T without any statements about it. Let's see how certain on the subject they are
    Guijohn likes this.
  16. ninja123456 , via OnePlus 5 Midnight Black , Apr 5, 2021 :
    This must be fake. Every time someone asks customer support their answer will be. We have no info. Stay tuned
  17. Deepak@1
    Froyo Apr 5, 2021
    Deepak@1 , via OnePlus 5 , Apr 5, 2021 :
    Same here
  18. alexisonza07
    Gingerbread Apr 6, 2021
  19. Waveform Modifier
    Marshmallow Apr 6, 2021
    Waveform Modifier , Apr 6, 2021 :
    Based on your logic. They did never settled, because bugs never settled.
  20. alexisonza07
    Gingerbread Apr 7, 2021
    alexisonza07 , via OnePlus 5T , Apr 7, 2021 :
    so why 5 series already settled? no more update for bugs fixes and security patch.. we know that this is the end of 5 series update support but they should fixed first some bugs before leaving us.A
