259
OxygenOS 10.0.1 for the OnePlus 5 and 5T
  1. Z1583072099746
    Cupcake May 10, 2021
    Z1583072099746 , May 10, 2021 :
    Media sound is shifted from speaker to earpiece when a call is made or received while any media player is on, and isn’t recovered unless phone is rebooted. Is this any update bug?
  2. J1620647695706
    J1620647695706 , May 10, 2021 :
    Maybe he wanted to point out that the CVE-2020-11292 was (according to news) reported to OEM vendors in December 2020 so the fix could have been included in the 10.0.1 release..
  3. Last edited: May 10, 2021
  4. Rohan.M
    Gingerbread May 11, 2021
    Rohan.M , May 11, 2021 :
    I am on A9 on my 5T with security patch of 1st feb 2020 , my teams app is working fine.
  5. Jvasava
    Cupcake May 11, 2021
  6. McJader
    Marshmallow May 11, 2021
    McJader , May 11, 2021 :
    I think you should, if you can.
  7. G_Deepak_Mishra_aZXL
    Cupcake May 12, 2021
    G_Deepak_Mishra_aZXL , May 12, 2021 :
    I cannot seem to find android 10 upgrade for my 5t. The current OS version is OnePlus5TOxygen_43.T.54_GLO_054_1906241434.
    Can anyone help me to upgrade to android 10?
  8. praeterflora
    Eclair May 12, 2021
    praeterflora , via OnePlus 5T , May 12, 2021 :
    I'm glad that we had finally got a somewhat stable build of OxygenOS 10.0.1, but before the final adieu would've loved to get the November security patch with the November update or at least give us one last security patch update last December as a farewell update. Just an opinion...but thanks for the update!
    tsounami71 likes this.
  9. adam1709
    Donut May 12, 2021
    adam1709 , May 12, 2021 :
    After all, it depends on your impressions, you know best how the battery holds now and how it was at the beginning. I have OP5 3.5 years myself and I do not even plan to change the battery because it is doing great.
    SmartUserS likes this.
  10. bawng_upa
    Honeycomb May 12, 2021
  11. bawng_upa
    bawng_upa , via OnePlus 5T , May 12, 2021 :
    My experience:
    Since Android System Webview crisis, I'm one of the victim till now.. Nothing suggestions or tutorial on how to fix this on earth didn't work for me.
    So I flash custom ROM.
    1. Arrow OS 11 GAPPs - After clean flash/install it's still the same as my previous OOS 10.0.1
    2. Pixel Extended - After clean flash/install it's still the same as my previous OOS 10.0.1
    3. Pixel Experience - After clean flash/install it's still the same as my previous OOS 10.0.1
    4. Lineage OS without GAPPs - After clean flash/install it worked fine but freeze sometimes, not as frequent as OOS, but I need Google so...
    5. Lineage OS with MindTheGaaps - After clean flash/install it worked fine but freeze sometimes, not as frequent as OOS, but I need to Bypass SafetyNet to use one of my essential (works) application. After I try to fix Safety Net and couldn't fix
    6. Oxygen OOS 9.0.9 - I downgrade my OS to Android 9(OOS9.0.9) which I am using right. This ROM is no different than other ROM, my phone still freeze, crash every application, system UI frequently.
    I will be very happy if someone knows how to fix Safety Net as in Sl. 5 that I've mentioned above.
    Thankyou.
  12. SmartUserS
    Froyo May 12, 2021
    SmartUserS , May 12, 2021 :
    op5-off topic: are there any possibility to get HD video quality on Netflix app instead of SD?
  13. bawng_upa
    Upgrade your plan.
  14. SmartUserS
    Froyo May 12, 2021
    i already have the 4k plan. the issue comes with L1 DRM old story. I'm not gonna send my phone to OP, but since then nothing has changed? Noone of the custom ROM can display content at HD resolution?
  15. bawng_upa
  16. zoomchandan
    Donut May 13, 2021
  17. Waveform Modifier
    Marshmallow May 13, 2021
    fostel likes this.
  18. fostel
    Cupcake May 13, 2021
    fostel , May 13, 2021 :
    I am still running stock Oxygen 9.0.11 (with xXx_NoLimits_8.6)
    Boot Loader Unlocked
    Rooted with Magisk 22.1
    TWRP 3.3.1-0 Installed
    Is it recommended to update to stock Oxygen OS 10.0.1 before flashing the newest LineageOS (Android Q or R)?
    If so, should I flash it through:
    1. OTA
    2. Oxygen Updater App
    3. Download and flash .zip manually using TWRP
    Thanks!
  19. Waveform Modifier
    Waveform Modifier , May 13, 2021 :
    I don't think you will need to flash the lastest stock OS. You will be flashing Lineage anyways.
    fostel likes this.
  20. G_aditya_chandra_BelT , via OnePlus 8 Pro Onyx Black , May 17, 2021 :
    I installed this oos and after a while I thought that because it is the 3rd major update that's why mobile has become slow and laggy.. simply I thought that device is slow because of the age of the processor..few weeks back I thought of installing lineage os..so I have samsung a5 2016 I installed lineage os 17.1 and it did wonders.then yesterday I installed lineage os 18.1 on my OnePlus 5 and my god phone is flying through everything.. it feels like I'm in 2017..now I realised that oos has become laggy and buggy and it's better to install another custom rom in your mobile if it is your secondary phone.
