259
OxygenOS 10.0.1 for the OnePlus 5 and 5T
  1. W1605388127344
    Cupcake Nov 14, 2020
    W1605388127344 , via OnePlus 5T , Nov 14, 2020 :
    My back stopped working(displays black screen upon opening the back camera) after couple of days of upgrading to 10.0.0. Hope this new build fixes the back camera.
  2. Jack the urbanist
    Jack the urbanist , via OnePlus 5T , Nov 14, 2020 :
    I was surprised how similar Android 10 is to Android 9. I actually went and checked my version to be sure the update worked. Dark mode is better, and it has the wellbeing and parental controls. As for battery life, I'm sensing a little better battery life. I just finished charging it fully to see how long it lasts. I'm 2 hours in and still at 88%. I've sent some texts and Pandora has been running since charge. No location turned on but bluetooth running. Wifi and data on. Yesterday I had 30% at the end of the day. Usually I'm closer to 15%, but that may have been a fluke day. Usually I only charge it to 80% to preserve the battery and so far that seems to be working. Camera EIS I'm not familiar with so I have no opinion about that. I did have a minor issue with it reverting from Microsoft launcher back to OnePlus launcher on wake. A simple restart cured that issue. I've made many calls and all calls have been great. I don't use voLTE because it never worked well for me on version 9 either. I think that's more a T-Mobile issue. I was also hoping for visual voicemail to work with dual sims. Alas that still doesn't work in 10.
    In summary, I find it working as expected with a few new features. Also things that were broken on version 9 are still broken.
  3. m0rtar0
    Donut Nov 14, 2020
    m0rtar0 , Nov 14, 2020 :
    i got the upgrade for OP5T this morning, until now( after 14h) the battery seems to go an extra 2 hours (15-20%) more than usual, I'll get back here with more feedback. thanks OP for the upgrade!
    Jack the urbanist likes this.
  4. Jack the urbanist
    How do you know? Have you compared your phone to everyone on android 10?
  5. _Aditya_Jain_
    Honeycomb Nov 14, 2020
    _Aditya_Jain_ , via OnePlus 5T , Nov 14, 2020 :
    How to access the app?
  6. Mayurpatil155
    Froyo Nov 14, 2020
  7. jontalk
    Ice Cream Sandwich Nov 14, 2020
    jontalk , via OnePlus 5T , Nov 14, 2020 :
    Thanks. Based on what you're saying I think I might stick with 9.0.11. I'm a very light user and can often go 4 days plus on a battery charge. The auto connect WiFi issue is definitely tied to the Google app too. Beyond that everything is snappy and performance is top notch!
  8. Nikskill
    Nikskill , Nov 14, 2020 :
    After updating I've noticed a bug with long notifications on the lock screen. You cannot expand them fully by sliding them down like I used to be able to.
  9. A1514078537796
    A1514078537796 , Nov 14, 2020 :
    like me ...now i have Android 9 hahahha ...no updat yet
  10. DoctorHe
    Eclair Nov 14, 2020
  11. doberman_baby
    Eclair Nov 15, 2020
    jontalk likes this.
  12. Murali_Manokar
    Froyo Nov 15, 2020
  13. NirajShakya
    Froyo Nov 15, 2020
  14. nzr150cc
    Eclair Nov 15, 2020
    nzr150cc , Nov 15, 2020 :
    I am new oneplus 5t user. Can I do an incremental update without the unlockbootloader? And how about the battery life?
  15. Itsme11
    Gingerbread Nov 15, 2020
    Itsme11 , via OnePlus 5 , Nov 15, 2020 :
    I have faced this issue earlier after 10.0 upgrade but it can be fixed..Just clean the cache in the phone app manually..long press on the phone icon and clean the cache storage..It works for me.Hope it will do
  16. sharkhark
    sharkhark , Nov 15, 2020 :
    Pretty much everyone.
    Go read any website covering the fact this update took too long and how the last update killed battery life.
    Every major website says the same thing.
    It happened to mine immediately after the bad update months ago.
    Stop saying this poster shouldn't mention the bad battery life killed by update.
    aero2 and F_Sayali_Nagrale_BGjW like this.
  17. nzr150cc
    Eclair Nov 15, 2020
    How is the battery life after this new update?
  18. NShankaraN
    Jelly Bean Nov 15, 2020
    NShankaraN , via OnePlus 5 , Nov 15, 2020 :
    Go to Settings>Privacy>Lock Screen and Select "Show All notification content" and check if it solves your problem
    A1588283988674 likes this.
  19. Nikskill
    Cupcake Nov 15, 2020
    Nikskill , Nov 15, 2020 :
    Unfortunately that was already enabled
  20. nzr150cc
    Eclair Nov 15, 2020
    Please help me. I am oneplus 5t new user. I want to update using oxygen updater. Can I do an incremental update without unlock bootloader? Thanks
