260
OxygenOS 10.0.1 for the OnePlus 5 and 5T
  1. Deactivated User
    Nov 16, 2020
  2. praveen.karre
    Gingerbread Nov 16, 2020
    praveen.karre , via OnePlus 5 , Nov 16, 2020 :
    Yeah! Supposed to do always, but most of the time we forget
  3. Akashdeep081095
    Eclair Nov 16, 2020
  4. TrimBat
    Froyo Nov 16, 2020
  5. D.Sai Suhail Baba
    Jelly Bean Nov 16, 2020
    D.Sai Suhail Baba , via OnePlus 6T , Nov 16, 2020 :
    I have been using it more than a month and have no issues with application. And it is supported for Android 9 Devices also.
  6. D.Sai Suhail Baba
  7. ichinisan
    Honeycomb Nov 16, 2020
    ichinisan , via OnePlus 5T , Nov 16, 2020 :
    People, give your system time before complaining about battery life, always check the obvious if no app is causing battery drain issues. Android can take quite some time before it is fully optimized so give it at least 24 hours.
    1605523094883.jpg said:
    My battery seems so far to be as expected. No excessive drain after giving it about 24 hours.
    Just be patient
    Ps: I hate the keyboard spacing, any workaround/fixes that do not require root to get the keyboard back to the bottom? This is the most annoying thing about this update.
    edit: said:
    fixed using adb command: "adb shell wm overscan 0,0,0,-85 "
    X1515404645804 likes this.
  8. EddieWho
    Froyo Nov 16, 2020
    EddieWho , via OnePlus 5 , Nov 16, 2020 :
    You can download a .rar of the update from the oneplus site (just google search "oneplus 5 android 10 stable download")
    You will have to check how to flash an update if you haven't done it before, but its not that hard.
    Good luck!
  9. Nashia
    Cupcake Nov 16, 2020
    Nashia , via OnePlus 5T , Nov 16, 2020 :
    There is a gap in the bottom of keyboard and the pbm is there while scrolling call history..seems like there is a bug when we select and are using navigation gesture (bottom). Full screen display is not working like before!!!😕
    Hope they will fix it in next update..
  10. Ak478
  11. Ak478
  12. G_Basant_Choraria_JaSE
    G_Basant_Choraria_JaSE , Nov 16, 2020 :
    hi team,
    today I downloaded and tried to install the new oxygenOS 10.0.1 on my one plus 5 nad now it's dead. it said that installation failed.
    I have been using one plus 5 and one plus 7T and this issue happened on my OnePlus5 . please assist in getting the same fixed asap.
  13. G_Basant_Choraria_JaSE
  14. C1515164494165
  15. Kamal Hans
    Ice Cream Sandwich Nov 16, 2020
    Kamal Hans , via OnePlus 5 , Nov 16, 2020 :
    My sincere advice would be to stick to 9.0.11. There's no evidence yet that 10.0.1 is a good update with no crippling bugs.
    Re the Google app I too faced the crashing issue. What fixed it for me was - go to playstore, bring up the Google app & click uninstall ;it won't uninstall of course but will roll back the updates. It'll work fine thereafter provided you don't update.
    TrimBat likes this.
  16. Kamal Hans
    Plz take it to an OP service centre, they'll help you. If difficult to do it yourself unless you're savvy with these things
  17. sharkhark
    sharkhark , Nov 16, 2020 :
    If you listen to 27dudette it's all in our heads. We aren't experiencing battery drain all of us all at the same time after a bad update.
    Your imagining bad battery life.
    skipperto likes this.
  18. sharkhark
    You tell him Buddy! He's got his head up oneplus's arse so deep!
    F_Sayali_Nagrale_BGjW likes this.
  19. skipperto
    skipperto , via OnePlus 5 , Nov 16, 2020 :
    Me too am facing google app crashing, i too tried to uninstall the update of the Google app, but still it crashes.
    Have also cleared chache and also later cleared storage, but that too didn't help.
  20. sharkhark
    I give a crap. This poster is just a fanboy oneplus asspony.
    All they do is keep shooting down user after user with the same negative experience.
    Without realizing? Hmm alot of people posting same concerns.
    Your wasting time trying to have a conversation my little dudette isn't original isn't helpful has the vocabulary of a teenage hormonal adolescent. Ignore them.
    Your right.
    I'm right.
    Everyone, so many, unhappy, are right.
    Dudette is wrong
    Rohan_S_P likes this.
