260
OxygenOS 10.0.1 for the OnePlus 5 and 5T
  1. D.Sai Suhail Baba
    Jelly Bean Nov 16, 2020
    D.Sai Suhail Baba , Nov 16, 2020 :
    It's issue with 5/5T software , bcz 6/6T users are not facing any issues.
    Imraj Ali likes this.
  2. neroxyr
    Eclair Nov 16, 2020
    neroxyr , Nov 16, 2020 :
    I have A9.0.11. A10.0.1 was showing me in the past week, but as today it's again A10.0.0, Are we a joke to you? Damn you OnePlus, your reputation has sinked and settled. Once a proud OP owner, but not anymore
  3. nzr150cc
    Eclair Nov 16, 2020
    nzr150cc , Nov 16, 2020 :
    Maybe what his mean that is no avaible yet on his smartphone.
  4. ganeshsharma527
    Froyo Nov 16, 2020
    ganeshsharma527 , via OnePlus 5 , Nov 16, 2020 :
    Do we lose data in this method?
  5. F1574680393269
    Cupcake Nov 16, 2020
  6. DogeAlpha
    Honeycomb Nov 16, 2020
    DogeAlpha , Nov 16, 2020 :
    There's a new option in the settings compared to 10.0.0 and it's not working for me. Im talking about "hide silent notifications in status bar"
    This being turned ON was the default on OOS 10 but when I turn it OFF it doesn't act like it's turned OFF.
    I want to see my silent notifications like OOS 9 and even when I disable the setting they're still hidden.
    Please fix this.
    This was one of my complaints on Oxygenos 10: silent notification icons being hidden, they added a toggle that fixes it, but the toggle doesn't work for me :((((
  7. A1605546372518
    Syamkumartg likes this.
  8. skipperto
    skipperto , via OnePlus 5 , Nov 16, 2020 :
    Okay, will do so and revert.
    Thanks.
  9. skipperto
  10. Nikhil Kumar Kansal
  11. Massimo1992
  12. m0rtar0
    Donut Nov 16, 2020
    m0rtar0 , Nov 16, 2020 :
    i didn't loose any data
    ganeshsharma527 likes this.
  13. NShankaraN
    NShankaraN , via OnePlus 5 , Nov 16, 2020 :
    I updated from 10.0.0 to 10.0.1. Have been using since 3 days
    1. UI freezes everyday when I wakeup the phone in the morning i.e., after a long idle time. No freezes in Chrome or UI in any other time.I have reported this as a bug to OP. If anyone knows any solution then kindly let me know
    2. Battery drain is same as earlier. I'm not a heavy user. I usually do phone calls for about 50-60 mins/ day and 10-15 mins of video calls and getting around 4.5 hrs of SOT on a full recharge which is good/decent in my opinion considering that my battery health is 80%.
    Battery idle drain is around 3-4% over a period of 6-6.5 hrs overnight with all apps killed and data + wifi turned off
    3. No EIS in 4K and 1080p 60fps(it wasn't there from the beginning). Although the EIS in 720p and 1080p 30 fps are not as good as they were in 9.0.11.
    Apart from these points, the call recording is working fine for me.
    I had enabled VoWifi through logkit in 9.0.11. So when I upgraded to 10.0.0 back in May I had the option toggle button for VoWifi and even in 10.0.1, I have VoWifi and it works fine
    Initially on the first day had issues in crashing of apps in my Work profile and it required reinstallation of all the apps in work profile.
    Gracjallini likes this.
  14. praveen.karre
    Gingerbread Nov 16, 2020
  15. ninja123456 , via OnePlus 5 Midnight Black , Nov 16, 2020 :
    Ever wondered the battery might be aged after using all these years?
  16. Shadink
    Shadink , Nov 16, 2020 :
    @NShankaraN
    I shoot alot of videos on my op5 and i can confirm you there was an EIS for 4K
    steakzauce likes this.
  17. jontalk
    Ice Cream Sandwich Nov 16, 2020
    jontalk , Nov 16, 2020 :
    Interesting feedback.
    Re: #1. Are you saying when you wake the phone up in the morning, touching the UI does nothing? If so, that's very strange.
    Would you agree 9.0.11 performs better than 10.0.1? I ask since I decided against installing 10.0.0 due to the countless problems. Based on what you and few others have said, I think I'll stick with Android 9.
  18. terminad0r
    Eclair Nov 16, 2020
    terminad0r , via OnePlus 5 , Nov 16, 2020 :
    I'm thinking about the same.
    I didn't upgrade to 10.0.0 due to the reported bugs, so I stayed with 9.0.11
    With this new announcement, I was thinking in updating to 10.0.1 directly, using Oxygen Updater.
    So, you guys recommend staying with Android 9?
  19. jontalk
    Between you and I, it seems logical to stay with A9. The security patch aside, it seems to me that OP's implementation of Android 10 was a big fail, regardless of model. Check out the A10 updates to other models and you'll see why. As the saying goes, 'if it ain't broke, don't fix it' :)
  20. stately
    Eclair Nov 17, 2020
    stately , Nov 17, 2020 :
    I wish I had found and read similar threads before updating to 10.0.0. The 5T became unusable for a basic telephone call and I had to fumble my way back to 9.0.11 where I plan to stay. It didn't matter if I bricked it, because I couldn't use it anyway. Now back on 9, the functions I use seem to work normally, and I am happy to have my notification light working again, too. I'm not a techie and don't plan to try to update to 10.? unless I see glowing comments here and everywhere. So please, everyone keep posting, because all knowledge is valuable.
