259
OxygenOS 10.0.1 for the OnePlus 5 and 5T
  1. Waveform Modifier
    Marshmallow Nov 17, 2020
  2. U1605555130820
    Cupcake Nov 17, 2020
  3. Dks_11
    Donut Nov 17, 2020
  4. ZahidulNadim
    Eclair Nov 17, 2020
    ZahidulNadim , via OnePlus 5T , Nov 17, 2020 :
    Thanks
  5. TrimBat
    Froyo Nov 17, 2020
    TrimBat , via OnePlus 5 , Nov 17, 2020 :
    Thank you for the information sir!
    Could you please provide the link to the keyboard gap ADB shell mod you used? Is there any inconvenient when using it? Thanks!!
  6. raghavkishore05
    Froyo Nov 17, 2020
    raghavkishore05 , via OnePlus 5 , Nov 17, 2020 :
    Wow tats wondering 😂 n wonderful congratulations..
  7. raghavkishore05
    Froyo Nov 17, 2020
  8. jontalk
    Ice Cream Sandwich Nov 17, 2020
    jontalk , Nov 17, 2020 :
    Simple. Use the Feedback/Bug report tool and chat with support. They're not going to reply here :)
    F_David_Rodger_MiiD likes this.
  9. jontalk
    How do you like it as compared with 9.0.11. This update seems hit or miss though I suspect many of the problems are tied to third party apps/games, etc.
  10. maxxx121
    Eclair Nov 17, 2020
    maxxx121 , via OnePlus 5 , Nov 17, 2020 :
    Hello OnePlus team,
    The audio recorder is still not working unless both the SIM are active. If I deactivate one SIM and then restart my phone, the call recorder again disappears.
    The call recorder feature also stops even without restarting the phone while one SIM is disabled after a certain time period.
    I have to activate both the SIM every morning just to enable the call recorder feature and then disable one SIM.
    I was really expecting this to be fixed, but the issue remains .. please see that it's fixed .
    Regards
    gopalan_md19 and ichinisan like this.
  11. F_Rahul_Shah_quyI
    F_Rahul_Shah_quyI , Nov 17, 2020 :
    good job oneplus.. i was about to throw my 5T, and got the 10.0.1 update.. now can easily squeeze in another year from the phone.
    surya1991s, gopalan_md19 and dariodoc like this.
  12. maxxx121
    Eclair Nov 17, 2020
    It's there.. you will have to enable both the SIM and then the recording settings will appear. Then you can disable the other SIM.
    Repeat the Process everytime when call recorder stops working
    This was same for 10.0.0 also and still after the new update which came after so many days it's still the same.
    gopalan_md19 likes this.
  13. Waveform Modifier
    Waveform Modifier , Nov 17, 2020 :
    This is a user community forum and not support.
    Please report your bugs properly at the feedback forum and not in the user community forum. This forum is largely viewed and maintain by users and not OnePlus staff.
    https://forums.oneplus.com/feedback
    SmartUserS and gopalan_md19 like this.
  14. ichinisan
    Honeycomb Nov 17, 2020
    ichinisan , via OnePlus 5T , Nov 17, 2020 :
    Check post 943 and 963
    No great inconvenience, some apps were showing wrong scaling, updating fixed it for some. Worst case you can revert back. It's nothing permanent
  15. ichinisan
    I downloaded the full update from oxygen updater,
    Some minor inconveniences like the keyboard gap, managed to sort that out so I can live with it.
    Performance seems so be ok. I don't like the response from the home screen to open the recents screen, it takes getting used to, but I dislike workflow changes. I still always miss the android 8 recents screen, that was way more convenient.
    Besides that battery life is much better on standby. I don't need to keep some apps from battery optimization which I had to in the past, so automatically battery life is better. But hard to judge after just 3 days. I'll need to test it for a week or 2 as consistency can change..
    I don't really play games so don't care much about that.
    Overall I'm satisfied for these past few days.
    But time will tell for sure.
    gopalan_md19, Itsme11 and jontalk like this.
  16. aero2
    Froyo Nov 17, 2020
    aero2 , via OnePlus 5 , Nov 17, 2020 :
    This screen was always dark and now out of sudden it's white. I don't remember changing anything.
    edit. It went back to normal after i changed preset theme in customization settings to vibrant tints and back to nuanced dark
  17. aero2
    Froyo Nov 18, 2020
    Ologu Alexandru Mihai likes this.
  18. robby@76
    Cupcake Nov 18, 2020
    robby@76 , via OnePlus 5 , Nov 18, 2020 :
    Both sim are active already in sim and network section
  19. Ologu Alexandru Mihai
    Gingerbread Nov 18, 2020
  20. tapasweedixit
    Eclair Nov 18, 2020
    tapasweedixit , via OnePlus 5 , Nov 18, 2020 :
    My View on OxygenOS 10.0.1 Update for Oneplus 5
    I'm writing this after using device for 24hours after update.
    - Thay solved mentioned bugs. (And also put some extra bugs)
    - Battery draining is normal.
    - Charging speed is low. Will take more time to charge 0-100.
    - Some time facing freezing issue.
    - Drawer is unresponsive some time.
    - Device is getting Lil'bit heat while continuously use.
    Expected more from OnePlus but from last two updates (Android 10) they are not doing work up to the mark.
