259
OxygenOS 10.0.1 for the OnePlus 5 and 5T
  1. Boggoman
    Donut Nov 19, 2020
    Boggoman , Nov 19, 2020 :
    I'm wondering if I could install previous version of the stock camera app.
  2. Auzzya
    Gingerbread Nov 19, 2020
    Auzzya , via OnePlus 5 Slate Gray , Nov 19, 2020 :
    The video gets cropped for stabilisation by software
    drl431 likes this.
  3. MvD66
  4. jontalk
    Ice Cream Sandwich Nov 19, 2020
    jontalk , Nov 19, 2020 :
    Are you saying you haven't installed any of the Android 9 updates and if so, why would you want this one? Regardless if you haven't rec'd the update notification, go to the Play store and install Oxygen Updater which will give you the download.. Hope it works well for you too
  5. amirul_lisan
  6. MvD66
    MvD66 , via OnePlus 5 , Nov 19, 2020 :
    Hi, thanks for the reply. Indeed I did not update till now. I have noticed for some time now I am not offered over the air updates anymore. "my phone" says I'm up to date 😀, or perhaps it should be 😢.
  7. jontalk
    Very bizarre...perhaps the IMEI number is black listed though not sure if that would prevent OTA updates either. I'd recommend doing a clean flash since you're moving up two Android versions rather than one. Personally I'm sticking with 9.0.11 since my phone performs nicely.
    MvD66 likes this.
  8. Deactivated User
    Nov 19, 2020
  9. A1605820683669
    Cupcake Nov 19, 2020
    A1605820683669 , Nov 19, 2020 :
    hi. the oxygen 10.0.1 update was pushed to my device this evening. since then, my second SIM (for a different country) does not work. what to do?
  10. JayJacks0n
    JayJacks0n , Nov 19, 2020 :
    Last normal stable version - android 9.0.11
  11. JayJacks0n
    Why in 10.0.1 such terrible electronic image stabilization when shooting video?
    Bring back the stabilization that was on version 9 of the android and the early versions.
  12. Vigneshkk
    Vigneshkk , via OnePlus 5T , Nov 19, 2020 :
    EIS is only there on papers now. Just to show they brought it back
  13. Shadink
    Shadink , Nov 19, 2020 :
    happened to me. try restarting your phone this might work for you as it worked for me
    tgavett likes this.
  14. Shadink
    Vigneshkk
    EIS is only there on papers now. Just to show they brought it back​
    Yeah, it's a joke. SHAME, Oneplus not only already falling behind other OEMs in updates but also struggles to deliver a feature that already existed.
    I WILL NEVER SETTLE when buying my next phone [e]1f609[/e]
  15. Elmar42
  16. G_Mario_Fitzpatrick_XUNZ
    Honeycomb Nov 19, 2020
    G_Mario_Fitzpatrick_XUNZ , Nov 19, 2020 :
    wait OnePlus 5/5T isn't supported by the OnePlus buds? lol dh..
  17. jontalk
    I'm curious about this since I don't shoot much video and am currently running 9.0.11. Having just received the 10.0.1 notification the details state that EIS has been added yet you say it hasn't. Are you using the native camera app and if so, where is EIS in the settings? Thanks
  18. Bodygard
    Gingerbread Nov 20, 2020
    Bodygard , Nov 20, 2020 :
    There's no EIS in the settings. EIS should've work normally when you select 1080p video but it doesn't.
    There's no EIS working on Android 10.0.1
    Not adding EIS would be bad when we had it in Android 9 but stating in the changelog they added it and in reality isn't there, it's another level of crook.
    Seems like oneplus likes to "play with our faces".
    steakzauce, Auzzya and Siddvank like this.
  19. jontalk
    Ice Cream Sandwich Nov 20, 2020
    jontalk , via OnePlus 5T , Nov 20, 2020 :
    Thanks. Being unfamiliar since I rarely shoot video I'm assuming recordings are shaky? Sorry for my ignorance. Just trying to figure out whether to update. Right now it seems that sticking with 9.0.11 seems best
  20. tgavett
    Cupcake Nov 20, 2020
    tgavett , Nov 20, 2020 :
    Thanks I've restarted the phone and also "forgot" and synced the headphones again with only a little improvement, but not sure if that's just my imagination. They're still not as loud as before. Weird issue.
