191
OxygenOS 10.0.1 for the OnePlus 5 and 5T
  1. bawng_upa
    Honeycomb Nov 22, 2020
  2. Nitin_PulekaR
    Donut Nov 22, 2020
    Nitin_PulekaR , via OnePlus 5T , Nov 22, 2020 :
    After the update 10.0.1 Battery is Draining more frequently.!!! Does anyone facing the same problem?? Less than a minute it's using up 3% !!! It's not solved.
    Guys do not update if u haven't!!
    Ps:- I was running on OS 9 but after updating on OS 10 feels like why I update. Made a huge Mistake!
    Issue's what I noticed
    Phone is lagging a lot in terms of performance
    Heating Very frequently
    Battery Drainage very drastically
    aero2 likes this.
  3. anmolgoel12
    Cupcake Nov 22, 2020
    anmolgoel12 , Nov 22, 2020 :
    after upgrading to 10.0.1 issues that I found is,
    1- battery draining very fast.
    2- not charging fastly even after showing charging rapidly.
    3- There is lagg in the system thought i am on 8Gb RAM.
    4- In landscape mode, notification panel gets locked, cannot change brightness, or location mobile data switching or any other option available in notification panel.
    H1508163699391 and siddiquianas like this.
  4. Rohan_S_P
    Ice Cream Sandwich Nov 22, 2020
    Rohan_S_P , via OnePlus 5 , Nov 22, 2020 :
    Getting 5.30 hours of sot with 9.0.11(3year old battery).
    and 4.30 to 5 hour sot with 10.0.1.
    Battery life of 9.0.11 is better.
    aero2 likes this.
  5. Raghuveer_Vasista
    Nitin_PulekaR likes this.
  6. VivekJagdale
    Gingerbread Nov 22, 2020
  7. herohl
    Froyo Nov 22, 2020
  8. Caomhin
    Marshmallow Nov 22, 2020
    Caomhin , via OnePlus 6T , Nov 22, 2020 :
    Do a Full Factory Reset
    After Backing up the phone.
    Go to Settings,
    System,
    Reset Options,
    ⚠️Enable Erase Internal Storage⚠️
    https://www.androidpolice.com/2020/07/18/how-to-back-up-your-android-phone-before-a-factory-reset/
    And here
    How to Backup Android Phone to Google Drive
    https://mashtips.com/android-backup-to-google-drive/
    ⬇️⬇️⬇️⬇️NEXT⬇️⬇️⬇️⬇️
    Try to Optimize the phone, this helps with Lag, Heat, Battery Drain and much more.
    Clear your recent apps, also set 3rd party apps to Optimize in Settings Battery, only leave the ones you need run in the background or to notify you such as messages, email, Google Services, oneplus etc on Intelligent control.
    After a couple of days, Check App battery stats at about 50% and see if there are particular apps using more resources than necessary.
    Guide to lower Battery Drain.
    spektrum2k11 likes this.
  9. Nitin_PulekaR
    Donut Nov 22, 2020
    But why I need to reset.? You developers think it's a joke every now & then to reset the phone whenever they we face a issue?
    Why to erase & reset everything?
    Never gonna buy OnePlus Device from now onwards.!!
    S1519061516577 and VivekJagdale like this.
  10. Nitin_PulekaR
    Donut Nov 22, 2020
  11. exxizor
  12. Nachiket.Gurjar
    Nachiket.Gurjar , Nov 22, 2020 :
    I am still experiencing battery draining problems after 10.0.1 on my OnePlus 5T. It all started after the previous update, thought it would have been fixed in this patch but I believe it's not. Is there anyone else who's experiencing heavier battery drain with this upgrade?
  13. Caomhin
    I am a user same as you, I am NOT a developer.
    If you want support, contact OnePlus directly.
    Report the issue directly to OnePlus Developers as a Bug report.
    And also contact OnePlus support directly to see if they have more information on your issue. Scroll down the page for contact and online chat details.
  14. PRANAYCHINNA
  15. Nitin_PulekaR
    Donut Nov 22, 2020
    Thank you. Will get in touch with developer team directly
  16. VivekJagdale
    VivekJagdale , via OnePlus 5T , Nov 22, 2020 :
    Dont bother resetting or using the battery optimisation tricks. I have tried it and it hardly made a difference of 10-15 mins of extra SOT.
    Its very clear that A10 has a serious bug resulting in severe battery drain. Also replacing the battery may not work cz its the software that needs to be fixed.
    You may try using the device connected to Wifi all the time. It helped me getting a SOT of 7.5 hrs with normal phone usage.
  17. Nitin_PulekaR
    Donut Nov 22, 2020
    Let me try
  18. VivekJagdale
    Let us know the results. Ensure you completely charge the battery and have it connected to wifi all the time. Check the usage when the battery is at around 5%
  19. Manohar_Pearl
  20. Maurizio_it_TR
    Froyo Nov 22, 2020
    Maurizio_it_TR , Nov 22, 2020 :
    You are master of doing what you want, but if you do not want to follow the advice they give you, do not post, I do not have the problems you complain, for my modest use the battery lasts 3 days with 4 hours of use, the rest is quite ok
