593
OxygenOS 10.0.1 for the OnePlus 6 and 6T
  1. joropamporo
    Gingerbread Dec 6, 2019
  2. K1557150505921
    Cupcake Dec 6, 2019
  3. _B_u_n_n_y_75_
    Cupcake Dec 6, 2019
  4. M1543135554576
    Cupcake Dec 6, 2019
  5. l1541517967364
    Donut Dec 6, 2019
    l1541517967364 , Dec 6, 2019 :
    plz don't update .after updating cell is lagging more and screen turns of suddenly ,even battery drain and heavy heating issues.
    1st worst experience with 1+ same on company.
  6. Francesco losito
    Eclair Dec 6, 2019
    Luca Floricel and l1541517967364 like this.
  7. snoop85
    Froyo Dec 6, 2019
    snoop85 , via OnePlus 6T , Dec 6, 2019 :
    Which apps are working for you? None of my ones are.
    I tried uninstalling them, still doesn't work.
  8. itsalyana
    Donut Dec 6, 2019
  9. Navneet Bhargava
    Honeycomb Dec 6, 2019
    Navneet Bhargava , via OnePlus 6 , Dec 6, 2019 :
    for battery consumption, give us 3-2 round of full charging (0-100%)
    and for lag after upgrade, remove your clear cache and wipe data under recovery menu
    this will help in lag free experience and better battery life... i will recommend to backup your data and hard reset it
    l1541517967364 likes this.
  10. Aleris
    Donut Dec 6, 2019
    Aleris , via OnePlus 6T , Dec 6, 2019 :
    Yeah but in the staged OTA OnePlus check the critical bugs before the complete distribution.
  11. Navneet Bhargava
    mentioned already it's staged rollout not global or incremental rollout
    STAGED rollout means it will reach to some user and broader day by day
  12. J1558288802960
    Donut Dec 6, 2019
    J1558288802960 , Dec 6, 2019 :
    same way even I'm waiting.. 🥺
  13. Ressurected_Bishwarup
    Cupcake Dec 6, 2019
  14. walterkt
    Cupcake Dec 6, 2019
    walterkt , Dec 6, 2019 :
    dirty update from 10.0 Stable, then Wifi and Phone not working at all, tried to do factory reset and reflash the OTA again, Wifi and Phone, everything working, but same issue comes again after root (Magisk manager patched boot.img)
  15. sachin_dabas
    Cupcake Dec 6, 2019
  16. 7H3_F41C0N
    Eclair Dec 6, 2019
  17. Abdullashaikh
    Asadahm likes this.
  18. Asadahm
    Donut Dec 6, 2019
    Asadahm , via OnePlus 6T , Dec 6, 2019 :
    what's the difference between a local upgrade and OTA ?
    i did local upgrade through a link which was provided in the very first comment of this post, which later was deleted . i wonder if it will be the same as ota ?
  19. Abdullashaikh
    Abdullashaikh , via OnePlus 6 , Dec 6, 2019 :
    it's a staged roll out, most of the people have received it, and don't worry the updated hasn't been halted
  20. Abdullashaikh
    it's exactly the same as the OTA! the only difference is you download it by yourself and in OTA the company sends it to you via a system update
    Asadahm likes this.
