595
OxygenOS 10.0.1 for the OnePlus 6 and 6T
  1. T1553600315679
    Cupcake Dec 7, 2019
    T1553600315679 , via OnePlus 6T , Dec 7, 2019 :
    The 2nd app is touch Pay.
    kuldeep_cn likes this.
  2. dearson007
    Cupcake Dec 7, 2019
  3. TrunksDBZ
    Froyo Dec 7, 2019
    TrunksDBZ , via OnePlus 6 , Dec 7, 2019 :
    it's related to update if you are facing yellowish screen issues set your calibration from Vivid to Advanced ..
    Dr Suhas S V likes this.
  4. atul1524
    Eclair Dec 7, 2019
  5. Kedarnath65
    Gingerbread Dec 7, 2019
    Kedarnath65 , via OnePlus 6T , Dec 7, 2019 :
    yes, it's common for all us,one is the default file manager from OnePlus,and the other files app is from Google,u know the same downloads app from Google in Android pie with some extra features.
  6. E1528389282093
    Froyo Dec 7, 2019
    W1575277191557 likes this.
  7. O1569333688947
    Cupcake Dec 7, 2019
    O1569333688947 , Dec 7, 2019 :
    okey fine...thanks bro
  8. sardaarbabu
    Eclair Dec 7, 2019
    sardaarbabu , Dec 7, 2019 :
    In my OP6 device post upgradation to android 10, In play store I'm unable to update applications.
    Is any one spacing same issue ?
    problem with keyboard also , performance is also not up to mark.
  9. M555555555555555
    Cupcake Dec 7, 2019
  10. Devendra hatode
    Cupcake Dec 7, 2019
  11. TrunksDBZ
    Froyo Dec 7, 2019
    Yes but don't worry go into display settings and change your calibration from Vivid to Advance ..
  12. rashi1995
    Cupcake Dec 7, 2019
  13. ravisoren007 , via OnePlus 6T Mirror Black , Dec 7, 2019 :
    Few Pro things I liked about Android 10 and Oxygen OS 10
    1- Smooth and Fluid U.I
    2- Lag free Experience
    3- Awesome features
    4- Security updates by Google directly
    5- Excellent Gestures
    6- Better Fingerprint scanner
    Few Cons I didn't like in Oxygen OS 10
    1- Battery Consumption has increased which let down pure Battery backup comparing to Oxygen OS 9.0.17
    2- Dark Mode should be implemented on U.I not on Google application it's kind of force dark mode I didn't like it personally.
    3- Need to fix Keyboard its way to using the bottom screen left empty space without any reason. It's not Good looking.
    I hope Next update will fix the issues.
  14. Susanta_Kumar_Rout , via OnePlus 6 Mirror Black , Dec 7, 2019 :
    Clear the data of Play Store & the try it will work
  15. Susanta_Kumar_Rout , via OnePlus 6 Mirror Black , Dec 7, 2019 :
    is there any Wifi issues??
  16. nmn_bhtkr
    Eclair Dec 7, 2019
  17. chaturnikhil
    Donut Dec 7, 2019
    chaturnikhil , via OnePlus 6T , Dec 7, 2019 :
    how to hide the navigation bar while watching videos in android 10
    the navigation bar doesn't retract as it used to is someone facing the same problem also could somebody tell me how to override the dark themes over apps
  18. Hariharan0605
    Eclair Dec 7, 2019
    Hariharan0605 , via OnePlus 6 , Dec 7, 2019 :
    Thank you team for working hard to provide us with an update at the earliest. One of the smoothest experiences I've had with this phone. Phone UI feels like butter.
  19. Vineet143s
    Cupcake Dec 7, 2019
