595
OxygenOS 10.0.1 for the OnePlus 6 and 6T
  1. lucavi
    Cupcake Dec 5, 2019
    lucavi , Dec 5, 2019 :
    thank you
    Liehjan likes this.
  2. Liehjan
    Lollipop Dec 5, 2019
    Liehjan , Dec 5, 2019 :
    Remember, rollback deletes all data so backup :)
    lucavi likes this.
  3. sanjey sniper
    Gingerbread Dec 5, 2019
  4. MALU8484
    Eclair Dec 5, 2019
    MALU8484 , via OnePlus 6T , Dec 5, 2019 :
    Come on guys, of you want ti upgrade Just use VPN Germany or oxygen updater.
    anyway thia update Ferla much smoother than the previous One (10.0), Great job
  5. lalitpnl16
    Froyo Dec 5, 2019
    lalitpnl16 , Dec 5, 2019 :
    na bro, they will be still posting cringe things like "haven't received my update plz somebody help me, i need this update oneplus"
  6. drkrishna
    drkrishna , via OnePlus 6 , Dec 5, 2019 :
    vpn Germany is not working
    mrgray likes this.
  7. soumyo1001
    Cupcake Dec 5, 2019
  8. sachin_dabas
    Cupcake Dec 5, 2019
  9. mrgray likes this.
  10. sanjey sniper
    sanjey sniper , Dec 5, 2019 :
    fingerprint response is still same as 10 not yet fixed the bug.only for 10-15times it worked normally and fast and after that again the same bug flashes out.apps are opening after few seconds when the fingerprint has been scanned.To unlock the phone the fingerprint response is slow as i said for only for few scans i had a good experience and after that the same bug flashes.
    battery is draining very fast.standy power consumption is very critical.
    playstore crashes suddenly.
    camera hangs and frame drop occurs.
    The major issue is the fingerprint,battery and camera that the bugs still exist and not yet fixed....
    fix these issues..... oneplus team
  11. lybo_spurs
    Cupcake Dec 5, 2019
    lybo_spurs , Dec 5, 2019 :
    I have following version .
    My question is if I update to the new version will I then loose all data?
  12. soumyo1001
    Cupcake Dec 5, 2019
    soumyo1001 , via OnePlus 6 , Dec 5, 2019 :
    Below issues still persist, don't know what they fixed in the build.
    Screen calibration
    Phone dialer - Speed dial to call history to contacts slide navigation gone
    Empty space at the bottom of the Keyboard
    Fingerprint scanner - you can't unlock with single tap just after device is locked. Either two taps are required or you have wait for 1-2 seconds for single tap unlock
  13. Roman941907
    Cupcake Dec 5, 2019
  14. KetanRaut
    Froyo Dec 5, 2019
  15. daagvdm
    Cupcake Dec 5, 2019
    daagvdm , Dec 5, 2019 :
    can't connect with WiFi. before update no issue. I removed WiFi and added again. no difference. Mac filter enabled on the WiFi network. without Mac filter it is working
    One + 6 oos 10.0.1
  16. lalitpnl16
    Froyo Dec 5, 2019
    lalitpnl16 , via OnePlus 6 , Dec 5, 2019 :
    you won't get the stable update since you are in beta..you need to rollback and install 10.0.1 if you want to
  17. P1535264021971
    Eclair Dec 5, 2019
  18. NikkiChowdary
    Eclair Dec 5, 2019
    NikkiChowdary , via OnePlus 6T , Dec 5, 2019 :
    Till now we did not get android 10 and oxygen os 10.0 ..
    now you are started rolling out 10.1 ......🤦🏻‍♂️🤦🏻‍♂️🤷🏼‍♂️🤷🏼‍♂️
    we are still on Android 9....?!!
  19. KetanRaut
    Froyo Dec 5, 2019
    Meet_GrimReaper likes this.
