595
OxygenOS 10.0.1 for the OnePlus 6 and 6T
  1. DATA®
    Eclair Dec 7, 2019
    DATA® , Dec 7, 2019 :
    nordvpn, canada
  2. jatinchhabria
    Donut Dec 7, 2019
  3. DATA®
    Eclair Dec 7, 2019
  4. D1543027868775
    Cupcake Dec 7, 2019
    D1543027868775 , Dec 7, 2019 :
  5. Artemus.
    Community Hero 2020 Dec 7, 2019
    Caoimhín likes this.
  6. Meet_GrimReaper
    Gingerbread Dec 7, 2019
    Meet_GrimReaper , via OnePlus 6T , Dec 7, 2019 :
    hi I'm sharing the list 9f issue post update on A10 on stable
    1 Mac address unavailable
    2 VOLTE Miss because of calls are not able to make
    3 DUAL file manager
    4 game space it buggy while playing fortnight gta Pokemon go
    5 camera 4k 60fps is not EIS
    6 video enhancer is not up to the mark
    7 fnatic mode has no GPU optimization
    8 finger print is bit slow
    9 step counter is good but how to track weekly steps or daily if found help me with it
    10 VO-WIFI MISSING
    HIDDEN SPACE IS WHAT IS AWESOME .
    ododav likes this.
  7. wmbaak
    Donut Dec 7, 2019
    wmbaak , Dec 7, 2019 :
    I did the following: uninstall Maps, re-install Maps, clear cache. Unfortunately it doesn't help.
    the first part of the spoken instructions you don't hear. Only de last part.
    E.q.: The instruction is: After 80 meters, go to the right. I hear: ...ers, go to the right.
    my other navigation app (Flitsmeister) works fine.
  8. Nasir10sidd7
    Cupcake Dec 7, 2019
  9. Artemus.
    Artemus. , Dec 7, 2019 :
    1. You won't get MAC addresses unless you turn on either WiFi or Bluetooth.
    2. Does your carrier support VoLTE or did you do the forced workaround?
    3. One is built into Android 10, the other is OP's file manager. Disable one or the other if this bothers you.
    4. Don't use it so I can't say much about this.
    5. OIS is better.
    6. Explain.
    7. Don't use it so again can't say much.
    8. Give it time.
    9. Update the launcher.
    10. Again, does your carrier support it?
  10. RBD94
    Cupcake Dec 7, 2019
  11. Meet_GrimReaper
  12. INDSAM
    Cupcake Dec 7, 2019
    Alex1681 likes this.
  13. Artemus.
    Turn it on in Settings. Contextual something-or-other.
  14. R1554254237580
    Cupcake Dec 7, 2019
  15. Artemus.
    Caoimhín and KinnyFaiFai like this.
  16. Uncletec
    Cupcake Dec 7, 2019
